New Trans Bearing, Where does everyone get their replacement Bearings from!?
Whats up everyone, I'm looking for some help in finding a replacement input shaft bearing for an r154 transmission. Its actually for an Aisin AR5 but OEM has been tough, and I can't find any other option. Hoping the r154 is the same size. I've gotta think there is a bearing supplier out there that has one to this spec sitting on their shelf. Any help is greatly appreciated. thanks!
![]() Join Date: Jun 2003
Trader Rating: (129)
why not remove the bearing, take measurements, call your local bearing supplier, and have them match it?
#4 | |
![]() Join Date: May 2006
you need Outside diameter (O.D.) x Inside diameter (I.D.) "shaft size diameter" x the thickness of the bearings. there's also the a tolerance for the I.D. and O.D. example
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
I think you can contact North International Limited, they offer the best bearings for all-purpose. I had bought SKF S71920 CD/HCP4A bearings from them at an affordable price.
+1 on call bearing manufacturers if the local one doesn't have em...thankfully I'm in an area with lots of local dealers/transmission shops for when I run into the same...
