08-26-2008, 07:30 AM | #421 |
since i want to run a 2871 .64 i figured i'd ask here.
is a MHG absolutely neccessary when running about 320 HP on a SR? as for injectors, should i run 550s or 740? i was planning 740s to keep the duty cycle as low as possible. |
08-26-2008, 11:34 AM | #422 |
a buddy of mine ran stock HG with a t3 turbo at 20psi for over a year as a daily driver.
if you plan on doing more power then go 740's. if you think you'll be happy at mid 300's then no reason not to use 550's. i did right at 400whp on 550's but that was pushing them pretty good. |
08-26-2008, 01:55 PM | #423 | |||
Trader Rating: (58)
Feedback Score: 58 reviews
The C1 to S3 statement does contradict to a point. I'm looking at things now with building a valvetrain for the car. With the higher rpm, the C1's will have the same power, but even more top end. JWT/Clark is a cam voodoo god, and essentially said they are the way to go for what I'm looking to do.
PS: I loved that old article...what a favorite of the sr20forum Quote:
Yes. All day, everyday, everywhere. Quote:
Want Air Conditioning in your SR20 Swapped car? Check out www.sr20acbrackets.com for more information! Quest Alternator Conversions for SR20! Check my Group Buy! Tired of lousy internal gates? Go external wastegate with one of my manifolds, Check out my group buy |
08-26-2008, 04:32 PM | #425 |
you know.... I think everyone is making too much of a big deal to a certain extent on how the cams affect the lag of the powerband...Now, if you go to a big cam where you have to upgrade your valvetrain, then yes, you will lose some low end, but if you are talking about tomei 256's vs. hks 264 step 1's or jwt S3's and S4's, i think they are negligable assuming the same turbo. In other words, from experience, GT2871r .86 is NOTICEABLY laggier than GT2871r .64 vs. the cams I mentioned above, if that makes sense. All in all, I am VERY happy with my setup. From my experience, GT2871r .86 with S3's REALLY sucked vs. my current setup of GT2871r with .64 housing and S4 cams.
08-26-2008, 04:36 PM | #427 |
definitely go with 740's. you will regret it if you don't.
08-26-2008, 11:27 PM | #429 |
everyone will shun you as i have been dealing with :-(
but pretty happy with emanage ultimate (covers face as people throw things) seriously, i set it up well enough to drive it to the dyno and he got it tuned pretty quick, car runs well with 740s and a z32 mafs |
08-27-2008, 12:13 AM | #430 |
I have to agree! I got 855's and soooo smooth!
I was the first to ever do an 850 cc injector tune with JWT (for SR20)according to the owner. they flow tested them before tunning my ecu and they were all actually 855 cc
08-27-2008, 08:17 AM | #431 | |
Which ones are you using? Im using Sards, I love em so much I named my baby Sard. |
08-27-2008, 10:32 AM | #432 |
anyone know where i can pick up some 850cc sards? i'm lookin to switch from my 810cc deatschwerks tto some sards
codyace - i know i was pushing the 555's, but what i also dont understand is how my buddy was using nismo 555's and somehow made 520whp on them using greddy emanage blue. they had to be modified or something. |
08-27-2008, 12:26 PM | #433 |
Trader Rating: (18)
Feedback Score: 18 reviews
520hp on Nismo 555cc ??? WOW I know for a fact that the Nismo 555cc injectors actuall flow 600cc so keep that in mind. I running the Nismo 555cc and I will be going to the dyno real soon. (GT2871 .64 JWT C1 cams, JWT ECM)
08-27-2008, 03:01 PM | #436 |
Wow this thread is kinda worrying me. All im reading is buy the 2871 .86 if you want turbo lag and less power. It just doesnt make sense. Im going to the dyno on Sept 4th but i don't have the mods yet to pull 400hp. Maybe when i get the engine really dialed in i can post again with the results. It just doent make sense.
09-04-2008, 10:35 PM | #438 | |
Still debating between gt-rs style and t04s... I did some research on turbobygarrett.com, and it appears (from my calculations) that the difference in trim from 56 to 52 trim means that the inducers are different sizes,
t04s = 74.83 mm inducer gt-rs = 72.11 mm inducer So the question now is, does that 2.5mm make a HUGE diffference? Quote:
613DriftWerks.ca |
09-05-2008, 12:27 PM | #439 | |
As long as your tuner knows how to set up the ms or lag time properly...
otherwise it's a boat ride from hell Quote:
Like Me on FaceBook ! |
09-05-2008, 01:04 PM | #440 | |
I went with the 56 trim, breaking in engine right now, so tune and dyno will follow shortly, what trim do you suggest or had the most success with ?
09-05-2008, 01:09 PM | #441 |
ya, I suppose, and its not THAT hard to make the t04s fit, really its a coupler for hte intake pipe, and a 90* reducing coupler, thats it...
613DriftWerks.ca |
09-15-2008, 10:19 AM | #443 |
Trader Rating: (58)
Well I have some results for my first time at the drag strip with DR's. Got 4 runs in, first two were garbage, but my best was an 11.65, with a 1.80 60'. That's with no launch control, and me being scared to slip the clutch to long, and essentially a road race alignment on the car. I'm pretty happy for my first real time out.
Some of my drag friends thing the car has an easy 1.7x in it, and will be even faster with a better launch control. I can't wait to get my meth pump back from Aquamist and see if I can improve with that, and or crank the boost a few psi to see what she does. I'm certain the car has a low 11 in it with a better driver. Not to bad for a .64 housing huh? hehe.
09-15-2008, 11:10 AM | #445 |
Trader Rating: (58)
Around 3000 lbs with me in it. It's dyno'd right around 400 whp now, 2 years in a row. I hope to redyno it in the next month or so. As always, this car isn't a drag racing car by ANY stretch...I'm a grip baby
09-15-2008, 12:30 PM | #446 |
im a garage baby lol. caue that is where my car has sat for most of the summer. chasing down stupid little bugs.
My Twin Scroll Gt30r Sr22det Build |
09-15-2008, 12:40 PM | #448 |
Getting mine re-tuned on E85 thursday morning. I'm hoping for near 400whp. Will post the new chart when I have it.
Previous #'s were 315whp + 290wtq at 1 bar on 91 pump. |
09-15-2008, 04:11 PM | #449 | |
Trader Rating: (58)
I wish E85 was more available at times near me
09-15-2008, 04:40 PM | #450 |
Yeah, there are only 2 places in my area that sell it at the pump but since I don't daily the s13 anymore its not a big deal to me. I've heard nothing but great things from local people using E85 so far. People say the car just overall runs way smoother & cooler temp wise which is nice since I'm in Phoenix.
