Old 04-15-2007, 06:56 PM   #31
PoorMans180SX
PoorMans180SX's Avatar
because with a 9k rev limit, the gearset in the 6-speed gearbox is about perfect. It's basically for fexibility.
I was originally planning a VQ30DET, but I like the fact that the VQ35 heads flow better, and have VTC, not to mention the option of upgrading to VQHR heads later.
Old 04-15-2007, 08:44 PM   #32
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Originally Posted by Turbo711
yeah, it's preferable to get a VQ30DET crank, as the crank has larger journals and is a bit stronger.
It's been proven larger journals although being stronger can consume more friction. Friction equals HP loss. Us KA guy's are looking into reducing journal size from the cranks to increase rev.
Just like NISMO does with there fully counter weighed cranks.
Here is some use full educational material on how cranks are designed to increase HP.
http://www.circletrack.com/techartic...ft_technology/
BigVinnie is offline   Reply With Quote
Old 04-15-2007, 09:09 PM   #33
PoorMans180SX
True, but are we gonna worry about that minute amount of friction loss on the street? Not really. I guess it's your preference.
KA's are totally different compared to VQ30's, which can rev to 9k.
Old 04-15-2007, 09:24 PM   #34
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Originally Posted by OptionZero
shifted the power band and raised the rev limit IIRC
the "Rev-up" engines make more power but they aren't really that much faster because of the lost torque
Rev-up engines were short lived. The New 2007 350z VQ is a whole redesign. Reinforced and strengthened block, lengthened stroke to square up the bore and stroke for higher revs i.e.7500 rpm redline. Symetrical dual intake and exhaust. 309 hp stock. The jury is out on the oil burning issue from previous engines which actually was 2005-2006 engines. The current engines are so new they have not had data back yet, the engine has only been out since January. On paper the New VQ is sick and primed and ready for Turbo or Supercharger.
New Video
Buy my mounts!
Old 04-15-2007, 11:16 PM   #35
BigVinnie
BigVinnie's Avatar
I don't know to much about the new VQ, is it adaptable and easier to boost from variable compression????.
My boy Dave blew up his 2005 350z when he twin turboed the damn thing (that compression wasn't meant for boost), it blew up before it hit the freeway....He's just lucky to be a fleet manager at one of the nissan dealerships.
Old 04-15-2007, 11:24 PM   #36
twofortyrida1388
twofortyrida1388's Avatar
twofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura about
Thanks for all the info. When I started this thread I was very curious about this swap but now I really want to do it. I have always loved my 4 cyl's but to me it makes more sense for this engine, its light, can rev higher, shorter length and height, more torque and new technology. The VQ as sad as it is to say it has surpassed the RB26 and 2JZ in max hp. The damn thing has hit 1800hp and still rising. 350z's are fast but imagine taking a 1000 pounds off it and then compare. There is a reason the 350z has been named import car of the year. On average how much do you think this swap would be if me and some fellow 240 lovers did the labor and just bought the parts? I know it all depends on luck and pateince but just an estimate.
Boost Coming soon...
twofortyrida1388 is offline   Reply With Quote
Old 04-16-2007, 12:03 AM   #37
BigVinnie
BigVinnie's Avatar
If you and friend did it the swap will cost around $5500. Theres a guy on NICO that just did the swap he charges $7500.....It's not a cheap swap. It's also a lot harder than you think. You have to change out the speedo/cluster, and also program the electric TB, and add an electric foot pedal. You alsohave to retrofit the transmission for the shifter. It's not an easy swap, and unless you are a Nissan tech you won't have all the rite equipment to finish the job.
Old 04-16-2007, 12:20 AM   #38
twofortyrida1388
Thanks man. My freinds are the electrical and tuning experts and I'm pretty good with the mechanical. Welding, measuring, a wrench. It won't be soon but I am def going with this swap. I would love to be pushing around 7lbs of boost on it too.
Old 04-16-2007, 02:48 AM   #39
Emp123
Emp123 is an unknown quantity at this point
About how legal is this swap? I know it will pass smog, as its sold in the US, but what are the laws on throwing an engine in a car that is from the same manufacturer and newer? Is there a law (or part of one) that states that the engine had to be sold in the model its being put into for it to be completely legal? (Im in Cali if that matters, and it probably does)
Emp123 is offline   Reply With Quote
Old 04-16-2007, 10:39 AM   #40
drift freaq
The law states any engine sold in the U.S. that is newer with all its smog equipment is a legal swap. That is California law.
New Video
Buy my mounts!
Old 04-16-2007, 11:40 AM   #41
Bushido
Bushido's Avatar
its actually not as hard or expensive as you're making it out to be...
VQ's can be had for next to nothing. i've seen maxima VQ's go for extremely cheap... if you got the interest and drive to do the swap, i say go for it.
the easiest way to get a VQ into a s13/14 is:
standalone engine mgmt
convert to mechanical throttle body
weld bellhousing from vq tranny to sr/ka tranny and bolt to VQ
bolt in engine using 33 GTR engine mounts
convert speedo: http://www.engineswaptech.com/forums/post/744.aspx
i can understand wanting to run the 6sp, especially since they can be had for only a couple hundred bucks, but it does require shifter linkage modification, custom driveshaft, and tranny mount, which complicates things a bit.
KA 5spds are plentiful and cheap. it probably wont last that long, depending how you drive it, but you can always swap another and it makes the swap alot less expensive.
Old 04-16-2007, 11:49 AM   #42
kenshinS14sks
kenshinS14sks's Avatar
kenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to beholdkenshinS14sks is a splendid one to behold
i thought it was an engine that had come in the car ... not just any newer engine from the US ...
facebook.com/SodiumDanceCompany
kenshinS14sks is offline   Reply With Quote
Old 04-16-2007, 12:06 PM   #43
twofortyrida1388
If you are from Cali with their crazy emissions I understand but here in NC nothing is a problem. We are basically givin inspection stickers.
Old 04-16-2007, 12:51 PM   #44
Emp123
But wont it like not pass the visual inspection? Or are they just checking to see if there are any turbos/all the emissions stuff is there?
Old 04-16-2007, 02:35 PM   #45
Emp123
The more I look into this, the more I want to do it.
Old 04-16-2007, 03:01 PM   #46
PoorMans180SX
Heck yeah man, it's such a sweet option that everyone overlooks. For a budget swap you can use a VQ30 out of a Maxima, with it's easier-to-tune ECU and mechanical throttle body. Look up Broaner, he has the first VQ(30) powered coupe in the States. I'm surprised he hasn't chimed in already.
Old 04-16-2007, 05:13 PM   #47
BigVinnie
BigVinnie's Avatar
O.k so what engine management would he need to run that isn't over a grand, it would make the build more expensive, than using all the existing OEM equipment and ecu.....
FYI here is the the entire build Spec D racing has done....
It's finished now..
http://forums.nicoclub.com/zerothread?id=207033
Originally Posted by spec D racing
ISCARIOT....
I appreciate your input, and yes, the Maxima Engine is cheaper, but there's more to a FWD conversion than I think you know. I have done the math and it is more expensive to use a FWD block. If you care to argue pricing and standalones, open a new thread for that. This thread is being posted to show how to do the swap with the Z ecu, make it run, and do it without a dyno. For 99% of the those reading this....this would be the way they would/will do it.
Again, your input is never unnappriciated, all input is good to show others different prespectives.
Old 04-16-2007, 08:11 PM   #48
Emp123
This swap looks much more complicated than a SR swap, but the power gained is crazy.....if only this swap brought a smile to my face like the RB25DET/RB26DETT swap does.
Old 04-16-2007, 09:33 PM   #49
twofortyrida1388
I love the RB's and all the 4's but this motor will get eaisier and easier the more it is done. Shit it is just as light as the KA but makes twice the power. The RB26DETT is godly and a beast but the VQ35 is lighter and makes just about the same power N/A (05' and up 350z,G35). You do a basic turbo setup and you got a beast. The center of gravity and 50/50 weight ratio with VQ35 will be better than RB25 and 26 because it sits lower and further back. There are some people already making a custom linkage for 6MT to sit where the KA's does. Thanks for all the input it makes me glad I started this thing.
Old 04-16-2007, 10:31 PM   #50
Bushido
Bushido's Avatar
O.k so what engine management would he need to run that isn't over a grand...
Megasquirt.
msglngth
Old 04-16-2007, 10:37 PM   #51
Emp123
twofortyrida1388 I totally agree, but theres something about having a Skyline engine that makes me really happy. Despite this, Ill probably go for the VQ. Awesome power, awesome weight, awesome price.
Old 04-16-2007, 10:56 PM   #52
BigVinnie
BigVinnie's Avatar
Megasquirt.
msglngth
Still isn't cheaper than an OEM ecu for $100. Plus like the man said that did the swap. OEM is gauranteed to make the power with no dyno tuning, you can start adding up the cost if you like. OEM is the cheapest route.....
Old 04-16-2007, 10:58 PM   #53
BigVinnie
BigVinnie's Avatar
Not to burst your bubble but the VQ is a skyline engine.......
Old 04-16-2007, 11:03 PM   #54
Emp123
Just not the Skyline from my youth. Although, I guess you could argue that the new Skyline is the Skyline of my youth.....
Old 04-16-2007, 11:13 PM   #55
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
Couple missconceptions in this thread that should be clarified.
VQ will not give you a 50/50 wieght distribution. If it wieghs a little more than a ka and we know the 6sp wieghs more than a ka trans. Even if it lower and pushed back slightly ka cars are usually 58/42 Even sr cars are only 54/46 most of the time or at most 52/48. If it keeps getting repeated in this thread that going VQ will give you 50/50 then it will go down as the word of god on internet forums even though it is a false statement. (if someone has a vq powered s14 and wants to prove me wrong please put it on the scales I am dieing to see it)
Also using a ka or sr 5sp is not a better option than using the 6sp. If you have to cut and weld a custom bellhousing how is that easier than cutting and modifing the linkage. The modifications that I have seen done on already swapped cars with z33 6sp doesnt look that bad, I would lots rather do that than Cutting and welding a new bellhousing.
Drive by wire should be eliminated for this swap into an schassis, there may be running drive by wire cars out there but its overcomplicating the swap. Just get a tb that is cable driven and make a custom bracket its pretty easy. Other than that awesome swap and anyone has done it I aplaud because its a pretty badass swap. I cant wait to see a built vq32 n/a monster locally so I can drive it
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
Old 04-16-2007, 11:17 PM   #56
Kyosuke
Kyosuke's Avatar
Kyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymoreKyosuke is not welcome here anymore
im too lazy to read all this right now but ill read later anyone see that 1 car ? ill post some pics in a min
Kyosuke is offline   Reply With Quote
Old 04-17-2007, 01:57 AM   #57
Emp123
I saw a video of that thing revving, it didnt sound to good, which is surprising because the engine sounds really clean in the G35/350z
Old 04-17-2007, 06:51 AM   #58
Bushido
Bushido's Avatar
no doubt it cheaper... but is it worth the hassle installing the NATS system and associated immob bullshit? can you say wiring nightmare? good luck getting it all going without a Consult II. I'd rather just spend a couple hundred more for a fully programmable system and bypass all the bullshit.
Originally Posted by brainfood
Also using a ka or sr 5sp is not a better option than using the 6sp. If you have to cut and weld a custom bellhousing how is that easier than cutting and modifying the linkage. The modifications that I have seen done on already swapped cars with z33 6sp doesn't look that bad, I would lots rather do that than Cutting and welding a new bellhousing.
no, the 5sp is not the better option, but it IS the easier one. using the 5sp allows the VQ to bolt right in. meaning no custom engine mounts, no custom tranny mount, no custom drive shaft, and no modification to the shifter position.
found these guys the other day: http://vqswap.com/index.html
they make kits that address all the problems above and are also working on a plug and play ecu solution
Old 04-17-2007, 10:04 AM   #59
PoorMans180SX
sick link bro! posi! I'm pretty darn sure you'll still have to use custom engine mounts with the 5spd though.
Old 04-17-2007, 11:03 AM   #60
PoorMans180SX
Pics of their swap they sent me. I think I'll mount mine a little farther rearward, but looks pretty good.
