#1 | |
GM2 (SW/AW)
S13 parts. Cleaning out the last of the Mohicans
Have a few things I'd like to get rid of, the last of my hatchback part out before I give the chassis to a friend. Prices are listed, pictures are being added here momentarily while I'm at work.
Need something not listed? Send me a PM and ask about it. I can ship some items if not most, but I cannot ship larger items. S13 rear calipers + soft lines - $50 OBO S13 'tan base' single piece pass. Seat - $50 S13 Gauge cluster trim - $15 S13 cracked up dash - $5 S13 Stock tail lights; Center garnish x2 Left light x1 Right light x2 S13 body harness (SOHC) Not sure if there's a difference between DOHC since it's just an interior harness? - SOLD S13 passive seat belt controller x2 - $20 S13 hood release $10 S13 Radiator - $10 S13 stock? front shocks - $20 (2 sets) S13 exhaust manifold and long tube (up to cat) - $15 S13 rear hubs on knuckles - $20 S13 rear upper control arms - $10 S13 Toe rods SOLD S13 Traction rods SOLD S13 manual tranny W/ shifter (missing shifter grommet & I lost a side plug for tranny. match it up for $5) - SOLD S13 PS pump mounting bracket - $10 S13 center console - $10 or $15 w/ash tray and cig lighter. SOLD S13 HB interior panels $5-$10 LMK what you need S13 white plastic carpet trims and hold downs $2-$5/ea S13 driver side lap belt (no receiver) - $8 S13 pass side lap belt (full) $17 S13 pass shoulder belt (BELT ONLY) - $20 S13 automatic belt rails + motor - $50/ea side S13 ignition switch SOLD S13 neutral safety switch & kick panel light $10 S13 rear anti-sway bar - $10 SOLD S13 KA fuel rail $15 OR $30 with injectors + caps INJECTORS SOLD S13 spare injector caps $2/ea S13 steering column gear (turn signal/wiper stalk assemblies) - SOLD S13 ECU kick panels (1) black (1) brown - $10 S13 green pass headlight cover $5 S13 headlight assemblies (no motor, OK condition) - $15/ea SOLD S13 B pillar covers (good cond, repaint them) - $7/ea S13 starter - $20 S13 center vents (no trim) - $8 S13 chuki bottom bumper vents - $10 S13 knock sensor (used) - $6 S13 knock sensor (new + harness) - $12 SOLD NEWLY ADDED; 888888888888888888888888888888888888888888 S13 White Automatic doors (No mirrors/Switches) - $100 for the pair / $60 single S13 Driver power switches - $20 S13 Pass. power switches - $20 S13 Door lock timer (little black box) $14 S13 Power interior harness (Pre-sale, haven't pulled this harness out to determine if it's cut or whole, it appears that it is though) - $120 shipped. S13 engine bay harness Fuse boxes and all - $108 Shipped S13 windshield washer reservoir W/ dual pumps - $30 shipped. Z32 MAF pigtail - $5 KA exedy pressure plate & clutchz APPROX 4-6K MILES - $88 shipped priority KA t4 turbo manifold (no name top mount) $15 Also have a few batteries for local guys only. *** I CANNOT GUARANTEE THESE WILL LAST ANY LENGTH OF TIME*** However, I will charge and test them with a printout of their condition prior to sale. Optima red top (side post) group size 78 Cranking amps - 1000 CCA - 800 Made in 2/2012 Asking $60 Optima yellow top (top post) group size D35 Cranking amps - 810 CCA - 620 Made in 9/2008 Asking $25 <b> <b> <b>
KA-T for life! Current for sale advertisement ![]() Last edited by anti tyler; 05-19-2014 at 03:59 PM.. |
#3 | |
GM2 (SW/AW)
Sorry about that, updated the listing. Around 4-6K I can't be 100% certain the exact mileage on it.
#4 | |
GM2 (SW/AW)
Bumpbumpbump
GM2 (SW/AW)
Last bump before I guess I'm throwing away half this stuff.
![]() Join Date: Mar 2009
how much for the sohc speed sensor?
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
#10 | ||
GM2 (SW/AW)
Last speed sensor I had went with the tranny on mothers day. any other parts you may need? Thanks for the props. Sweat my ass off this morning in this heat, but you got it!
#11 | |
GM2 (SW/AW)
Updated the list, added some new goodies I just got from my new purchase. Power gear etc. Let me know if there's anything specific you're looking for!
Always accepting trade.
Driver door [email protected]
Driver door window lock switch avail? And guage cluster? Thx joel
#13 | |
GM2 (SW/AW)
All power gear still available.
#15 | |
GM2 (SW/AW)
Switches and motor are seperate. if you want the motor I'd have to pull it out of the door first.
#19 | |||
GM2 (SW/AW)
Manifold is for DOHC, The manifold doesn't include the long pipe to the cat, if it did shipping alone would be over $50. Already got a quote on that. The sale is for the manifold only. If you need a cat also I do have that too.
#20 | |
GM2 (SW/AW)
Power doors switches etc sold along with interior power harness. Everything else still up for sale. Including a good condition exedy clutch!
