Old 09-11-2013, 08:32 PM   #1
rbs14kouki
rbs14kouki's Avatar
my s14kouki sr20vet
Sup guys ! My name is P-O (pierre-olivier) , i'm from Montreal , Canada
my built thread info will be on the second post
you may know me from my old car (rb26dett s14 kouki)
RBS14 - YouTube
i was doing drift event here and there , and was getting more and more confortable with it ...
it was now time to make a race car out of my little street baby !
the chassis work was all done !!! now was time to up-grade my stock twin turbo for a single
never mind my friend :P
little compression test before buying all my stuff ! compression is low -_-
déjÃ* vue !!!!!
the first year i had my rb in it the engine seized (that was after a rebuilt / full forged engine)
thinking its a head gasket , i lift the head up and this is what i found ! all 6 cylinders were the same
this was my second forge rb26 ! since i wanted to drift in dmcc and be reliable , i parted out all my rb swap to finance a ls1 swap
out with the old
in with the new
decided to refresh the ls1 before swaping it in
with all the sikky part list
engine and g-force ready to go Inside the engine bay
s14 with the ls1 Inside her
chassi work was needed to fit the transmission
i was at around 4k$ away to start the car !!!
26 year old and i was still living at my dads place ... with my girl for 3 years allready
it was now time to buy a house ... so i decided to part-out the complet car to get money for my down payment
first thing that was sold was the transmission set-up ... with-in 3 days it was online it got sold localy
next was the chassi (this was the hardess thing i had to let go ... it was my first s-chassis and the cleaness)
then a couple month later the engine was sold
i had enough money for my cash down on the house
time to start the construction
little tour of the house once all finish !
now that my house was done ... i was missing driving my s14 , got abit of money back and made a move on a car ...
found this s14 kouki 1997 from detroit on here ... it had a rod Knock on a s14 sr20det , new precision 4828 , ame ems2 , 740cc enjectors , bc head , j30 brake , new froint lip fron nissan dealer .... for 4k$
made a cash down via paypal and drove with my Buddy to go get the car
i took the engine out to fix the problem ... at the same time my Buddy puts for sale a stock s14 sr blcok with a p11 head attach to it for 800$
i bought that shit in a heart beat
used this stock block for the rebuilt of my kocking sr (i changed the rings , honed the block) and the nocking sr for my ve (it was needing a crank and a bore)
at the machine shop (top det built , bottom ve built)
i had a brand new s14 sr for sale ... and my bro took it for is zenki he had bought
time for the built thread to start !!!!
AV FABRICATION
Built thread sr20vet s14
#/f/showthread.php?t=535574
Old 09-13-2013, 06:34 PM   #2
Whitesil80315
Whitesil80315 is making a name for him/her selfWhitesil80315 is making a name for him/her self
This turned out to be a sad story.....dislike!
Whitesil80315 is offline   Reply With Quote
Old 09-13-2013, 07:35 PM   #3
rbs14kouki
rbs14kouki's Avatar
here for my built info
head:
p11 head
p11 cams for the moment (but im looking for a set of p12)
p12 valve cover
brain crower cam gears
supertech 123lbs dvs
stock valve for now
mazworx intake newest version
mazworx hallsensor kit
mazworx vvl conversion kit
mazworx fuel rail
sr20vet head gasket
bottom end:
s14 block (decked and O-ring)
cp sr20ve pistons 86.5mm 9.0:1
manley H-beam rods
det crank
acl race bearing
new timing chaine kit
new sr20ve oïl pump
new s14 sr water pump
moroso oïl pan
taarks oïl filter relocation kit
taarks power steering relocation kit
codyace Quest alt kit
Doc race sr20ve manifold with v-band flange and mvr waste gate flange (i provided a sr20ve flange to them ... flange from taarks)
new seals everywhere
Drivetrain:
Os giken TS2BD twin plate
cd009 z33 transmission
collins or mazworx adaptor plate (dont know yet)
most likely will have a welded 4:10 gear or a 1.5way carbonetics with 4:10 gear
Cooling:
c&r custom rad
an fitting welded for rad hose
swirl pot custom made
oïl cooler and power steering cooler
hot side:
precision 5858 ar.63 v-band housing
precision 46mm wastegate
custom down pipe
fuel:
aeromotive stealt 340lph (single or dual in-tank ... im not sure yet)
id1000 injector
electronic:
AEM ems2 with custom wiring
AEM boost controler
aim cluster will be needed (i dont want 6 or 7 gauges)
exterior:
i still have my D-max type3 body kit
looking for bn sport front and rear fenders
that about it for now
since im going over fenders my front end is all for sale localy here in montreal , canada ...
Brake: (looking for a deal for the moment)
ill be looking for a evo x front brake set-up ... my Buddy works in a shop that preps rally evo's and the stock brake a too big for those cars from what i understand ... so ill pick a set as soon as i have abit more money aside !
rear im not sure yet ... z32 most likely but i think evo rear with z32 rotor works with spacers so ill need to read more in to this
suspension: (nothing purshase yet)
fortune auto 500 with swift spring upgrade will be my chose of coilovers
gktech suspension arm or spl
pbm front knuckle
wheels:
nothing yet
here are a couple pictures :
when i first got the head
mazworx shipement that came in at the same time as my Buddy sr24vet
this is Dave Briggs sr24vet formula D engine
now with my parts
o-ring block with pistons in it
Taarks oïl plate
head on the engine
with the p12 valve cover
now with the mazworx vvl relocation kit
i didnt like where mazworx was relocating the solenoids ... so i did custom hoses and relocated it Under the intake
this is when i brought my engine back home next to my s14
with taarks power steering relocation bracket
and this is my custom swirl pot that was inspired by Under Suzuki timeattack s15
under Suzuki:
mine:
now im waiting for my doc race manifold to be shiped back to me ... after that its going to be turbo time ...
AV FABRICATION
Old 09-13-2013, 07:36 PM   #4
rbs14kouki
rbs14kouki's Avatar
Fr Sport was realy helpfull with my problem ... they gave me the mesurement from the alt pulley spacer that i lost in the process of fixing the power steering pulley
those pics are from my engine tech thread : #/f/editpost.php?do=...postid=5379077
ok here is the deal ... i bought a pulley set from fr-sport ... it came with 4 pulley Inside . (water pump , power steering , alt , ????)
when i instaled the power steering on the engine nothing was lining-up
i figure out the problem ... it was the right size compare to the stock one but was machined like a ka24de pulley megan racing
here is a picture to show how it was machined
if i flip the pulley (to make it fit for the sr configuration ), with how it was machined i couldnt bolt it . the shaft of the power steering pump wasnt long enough
so i machined down the exterior face of the pulley to have enough thread stiking out ... when i bolted the pulley for the first time , it wasnt seating right .... took my stock sr pulley and mesured the Inside spacer that was built-in the stock pulley (5mm)
from how my pulley was made i only had to do a 4mm spacer
now it perfect ...
AV FABRICATION
Old 09-13-2013, 07:37 PM   #5
rbs14kouki
rbs14kouki's Avatar
the transmission is in need of a rebuilt ... my Buddy gave it to me
it's from is 450whp z33 (second gear wasnt going in past 3500rpm , the rest was ok)
since i dont have a transmission for my set-up and was going to go with a z32 .... i decided to rebuilt this one and run a 6 speed on the ve :P
took everything appart to check whats wrong with the second gear ...
i though i only had to change the second gear and baulk ring ... but since im all ready there ... 3 and 4 would need a change too . in those pics you clearly see the syncro on the second gear side they are all shape on a diagonal ( / ) and not like the should be like an *Arrow*(­­­­ ^ )
at the local dealer ship here in canada , i have for 1200$ of parts to buy ... i looked around on the net and 550 + shiping from the usa to my house !!!
not to bad for a free transmission . i could try to just change the second gear but i dont feel like doing this again cause its a pita !!!!!!
AV FABRICATION
Old 09-13-2013, 07:39 PM   #6
Whitesil80315
Much better...Dudes got Arab money!
Old 09-13-2013, 10:29 PM   #7
Pinggg
Pinggg's Avatar
Damn, this is gonna be killer.
Old 09-18-2013, 05:26 PM   #8
rbs14kouki
rbs14kouki's Avatar
Just got a word from DocRace ! My mani is on its way
:P super pumped right now !
AV FABRICATION
