S14 Triple Din Gauges
just like the title what you see is what you get
SOLD
Nissan S14 Navan Zenki Last edited by s14canyoncity; 06-11-2010 at 09:30 AM.. |
![]() Join Date: Jun 2008
![]() ![]() ![]() Feedback Score: 11 reviews
Or above depending on how creative you are. I mounted mine above the radio.
GLWS to the OP. Edit: If you flip the lens you can get the the gauges to aim to the driver unlike the original RHD position. Last edited by Homer_Simpson; 06-08-2010 at 11:11 AM.. |
![]() Join Date: Jul 2008
it's only plug and play if you have the JDM under dash harness. On the back of the cluster each sensor wire from the plug is labelled. The only 2 you have to worry about is the
boost pressure sensor wire - use the one that you got in the swap. Cons- it only goest to 7psi. and the oil pressure sender |
#8 | |
here the instruction for the install real easy i had it all going to the gauge cluster lmk if any one wants this PM me price is OBO shoot me an offer i cant refuse ..or trade for a s14 oil pan.
Nissan S14 Navan Zenki |
