![]() Join Date: Oct 2008
S13.4 Conversion questions
ok i gotta 89 coupe w/ silvia front end i want to go 13.4 front end i just need a list of things i will need to make this work...and can i use the bumper support that is on my car now with the silvia conv.?
as of now i know i need: kouki headlights kouki bumper kouki grill kouki hood ......what else do i need please be specific just to help out more thanks |
Just find some USDM head lights. The head light beam will be pointed in the correct direction.
Do need the Factory Service Manual? Click here. |
![]() Join Date: Nov 2006
kouki hood
kouki oem fenders(if you want to use them and not fibergalss ones, you just need to cut the fender where it goes up around the windshield) kouki headlights(with pigtails so you can wire in the high beams as well as the h4 low beams which will be plug and play) kouki corner lights(you will use the light that goes to your silvia corner light) kouki front bumper and bumper support(so the bumper dosent have a nasty sag in the middle) kouki turnsignals(you will use your silvia turnsignal plugs) And then make your own custom brackets to hold the lights on. but if you use the oem bumper support and the oem fender that wont be hard at all..
92 vert converted 5speed and other little things
![]() Join Date: Jun 2003
Trader Rating: (129)
s14 hood hinges too. or custom
i used an s13 bumper support, but had to cut the about 5-6" off each end to clear the turn signals. my car (i'm whoring it up) \/\/\/ |
I used s14 hinges too, but had to cut off the little top part that sticks up when it closes. Conversion fenders, I paid extra for the brackets but did NOT need them, just get some metal and bend and drill it to fit the headlight brackets and bolt it into the stock places as well. OEM CF hood, origin kit, and conversion fenders and fit pretty well, I can put up a pic if wanted but you get the idea if not.
#9 | |
id like to see it! |
