![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
These are going for $320 picked up or $350 Shipped to lower 48 states (California customers add 9.25% to shipped price.) The Godspeed Project massive angle kit is a direct fit kit without any modification to your stock oem knuckle piece. This massive angle kit is a ONE PIECE MADE kit, unlike most kits out there that are cut and weld with the oem steering knuckle. This is made by an oem manufacturer with oem quality material. Godspeed Project massive angle kit will give you more extreme angle on your S13, S14, or S15 without modifying the front lower control arm. The Massive angle steering kit will stop at exactly 55 degrees , if you modify the lower control arm bump stop this angle kit will give you additional 5 to 10 more degree (Depending on how you modified your bump stop) We are confident in our product that we are offering a limited LIFETIME WARRANTY. OEM knuckle vs. Godspeed Knuckle Leading wheel: OEM is 38 degrees vs. Godspeed is 56 degrees Trailing wheel: OEM is 30 degrees vs. Godspeed is 46 degrees Turning circle (curb-to-curb): OEM is 30.1 feet vs. Godspeed is 23 feet Lock-to-Lock: OEM is 3 turns vs. Godspeed is 2.6 turns ***Note: For S13 240sx customers this must be use with a s14 240sx wheel hub. Also included is (2) 7mm spacers to go into the inner tie rod to be used with this kit****
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject Last edited by Fatboy Garage; 05-08-2012 at 07:42 PM.. |
Trader Rating: (35)
![]() Feedback Score: 35 reviews
Do they fit both s13 and s14 lower ball joints? Isnt the s14 ballpoint thinner, hence you'd need different knuckles for each model?
Anyways they Look good and the lifetime warranty helps the rep of These even tho it is Godspeed stuff. |
#10 | |
![]() Join Date: Nov 2007
Would you recommend just switching to an S14 FLCA with the added benefit of moar camberz? |
#11 | |
As far pictures go, there are more pictures on our website;
NISSAN 240SX S13 S14 89-94 95-98 MASSIVE ANGLE STEERING KIT [SK-001] - $450.00 : GodSpeed Project, The Art of Performance Quote:
You can switch to a S14 FLCA but its not necessary. On the knuckle itself you can actually bore out the hole just a tad bit to fit an S13 FLCA the size difference is not that big.
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
![]() Join Date: Jan 2006
s14 ball joint taper is different. if you get s14 knuckles on a s13 you need s14 balljoints in your lcas or s14 lcas. and the coilover bolts are 14mm on s14 vs 12mm on s13. you will need to either drill out your coilover holes to bolt up the knuckle or get these:
Agency Power AP240-500 5 Lug Shock Mount Spacers 240SX S13 S14 |
In stock ready to ship!
This is still available.
#17 |
still in stock!
These are still available!
#19 |
50% off sale going on today, last day.
#/f/advertiser-announcements-feedback/420917-godspeed-project-black-friday-special-50-off-msrp.html
#20 |
#22 |
Still have a few of these available!
#23 |
Still have a few sets left.
#24 |
Still have these available!
#25 |
In stock ready to ship out!
#26 |
Still in stock ready to ship out!
#27 |
in stock ready to go!
#28 |
#29 |
#30 |
