![]() Join Date: Jan 2008
TOMEI ARMS Turbo Kits On Sale ! M7960 and M8270 for SR20det !!!
![]() Zerolift is Proud to offer TOMEI products to Zilvia Members. The Latest sale is for the ARMS Turbo Kits for SR20det. The Tomei ARMS kits are the most complete bolt on upgrade we have used here at Zerolift. They include Turbo, Lines, Fittings, Flanges, Gaskets, Intake Adapter, Coupler ... literally everything.... Even 4 new Exhaust Studs for the Manifold. Both the M7960 and the M8270 Kits are on sale. Zerolift Pricing for the ARMS kits will be $1251.00 Please let me know the following when making an inquiry. - Which Kit you are interested in. - S13 or S14 Motor - and City, State, Zip Code Tomei Info : ■ M7960 TURBINE KIT This model is designed for low to mid range torque characteristics. The response is immediate with the light use of the throttle. Max boost is achieved by 4000 RPM. Best suited for street tuned cars and weekend track machines. Great for drifting, and grip race applications, with the best driving characteristics. PART NUMBER: 173019 $1,390.00 (USD) ■ M8270 TURBINE KIT This model is designed for high power at high RPM. With full boost on the bench test at 4,500 RPM and will maintain it all the way to high RPM without dropping. This will best suit the dedicated track cars that need best power at high RPM. PART NUMBER: 173020 $1,390.00 (USD) Please see the pictures below : Please let me know if I can help you with anything. Thank you, Robert
Contact: Phone - 513-874-2508 AIM - ZLR0bert Email - [email protected] Zerolift facebook - http://www.facebook.com/Zerolift |
That is correct, they are not a ball bearing turbo.
The 7960 turbo is rated for up to 400hp
The 8270 turbo is rated for up to 450hp
![]() Join Date: Nov 2008
with a small t2 turbo like said turbos, journel vs ball bearing will not make that great of a difference in lag, and since you have to ask if tomei makes any BB turbos you could get one of these and just tell yourself its BB you'll prolly never know the difference
#13 | |
with a Power FC within the next 2-3 weeks. We will keep you guys posted on the results.
#17 | |
![]() Join Date: Jun 2011
#19 |
Tomei Kits still available !!!
#21 |
The S14 with the Tomei kit made 318WHP at 16PSI.
Engine upgrades were - Head Gasket, Head Studs, 750cc Injectors Front Mount Intercooler, Turbo Manifold, Turbo Elbow, Full Exhaust. Tuned with Power FC D Jetro.
#22 |
![]() Join Date: Oct 2006
was this with some other exhaust mani? or the tomei unit? also do u think numbers would be different with a freddy included in that setup....also i have 555 injectors...would u recommend upgrading to 750s?
