03-12-2014, 06:47 AM | #1 |
S13 Bad Knock sensor Question
My KA24DE is chugging gas like crazy. Code 34, which is the knock sensor code, comes up. Is this what's giving me poor gas mileage? Or could it be something else? I had a bad Coolant Temp Sensor as well which made my MPG around 12-15 and erased the codes. Now it's at least at 14-17. I need to check my connections for it.
Sent from my Samsung Galaxy S4 |
03-12-2014, 08:02 AM | #2 |
Bad knock sensor will retard the timing affecting gas mileage. Replace the sensor (pain in the ass). The other way is to put a 1 mega ohm resister in line. There is a write up somewhere. If you are running a na ka setup the resistor trick will work fine. Cut the plug off the knock sensor not he harness side. Jump the two wires with the resistor (resistor between the two wires). Plug new resistor plug you made back into engine harness and clear the code and your done.
Sent from my SAMSUNG-SGH-I337 using Tapatalk |
03-12-2014, 08:05 AM | #3 |
Z1 motor sports sells a pre made resistor plug for this for the z32. It is the same for the z. It is a plug and play part.
03-12-2014, 08:09 AM | #4 |
03-12-2014, 12:32 PM | #5 | |
03-12-2014, 12:43 PM | #8 |
Thanks. True. One quick questions. Ive seen the write up but do you know if the sensor is attached to the block where the intake manifold is or below it?
03-12-2014, 12:47 PM | #11 |
It's under the manifold. Almost centered. You kind of have to use the sub harness as a way to guide the sensor in and out.
03-12-2014, 12:59 PM | #13 |
Yes volt meeter. The sensor is located under the manifold almost in the center of the head. Unbolt the sensor and uses the sub harness to pull it out. To reinstall use a coat hanger taped to the sensor and sub harness. To help guide it back in place. It is a real pain. If you are replacing the harness replace the sensor also. It's a 2 wire connector from under the manifold on the front of the engine.
03-12-2014, 01:27 PM | #14 | |
Just fix the problem, don't waste 16 bucks on that plug when for 6 bucks more you can do it the right way and get a new sub harness from wiring specialties. Or if you are deadset on the resistor go buy a resistor for under a buck and do it that way.
http://www.wiringspecialties.com/connectoru.html
Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
03-12-2014, 01:31 PM | #15 | ||
03-12-2014, 06:04 PM | #16 | |
03-13-2014, 11:12 PM | #17 |
I am currently battling this same issue i replaced my knock sensor it was cracked also replaced the sub harness with it, reset the light same knock sensor code comes up i cut the wiring harness open and traced the insulated wire till it splits off into 3 black wires one goes into the engine bay the other 2 go to 2 plugs. I checked for continuity from side plug side B and #27 on the connector for the ECU, it has continuity what the hell am i doing wrong
GO DUCKS!!!!!!!!! |
03-14-2014, 01:42 AM | #18 |
[QUOTE=Juantwo3;5583136]I am currently battling this same issue i replaced my knock sensor it was cracked also replaced the sub harness with it, reset the light same knock sensor code comes up i cut the wiring harness open and traced the insulated wire till it splits off into 3 black wires one goes into the engine bay the other 2 go to 2 plugs. I checked for continuity from side plug side B and #27 on the connector for the ECU, it has continuity what the hell am i doing wrong
Sent from my iPhone using Tapatalk[/QUOTE how do reset the code? by removing the negative battery terminal? |
03-14-2014, 04:39 AM | #19 | |
[QUOTE=tom_sr20;5583226]
03-14-2014, 08:39 AM | #20 | |
No i have an obd1 scan tool that has Nissan from 89-92 i can clear the code Sent from my iPhone using Tapatalk
GO DUCKS!!!!!!!!! |
03-14-2014, 02:26 PM | #21 | |
[QUOTE=Juantwo3;5583385]
03-14-2014, 02:55 PM | #22 |
No its an auto logic scanner, and i dont need help clearing the code lol i need help fixing the problwm
GO DUCKS!!!!!!!!! |
03-14-2014, 02:58 PM | #23 | |
03-18-2014, 08:09 AM | #24 | |
