![]() Join Date: Nov 2010
my attempt to make a decent onevia
so i picked up this coupe on my birthday its a 1989 240sx coupe with a cam'd ka24e on eibach lowering springs and 17x9 rota grids
got it home and installed some stance coils i had from my last car and brand new pbm rucas swapped to a chuki front end that i had on my other shell then my buddy wanted to take pictures of my car the motor just randomly stopped working while i was driving it so i pulled the ka and picked up an sr started pulling the motor apart because i bought it with a spun bearing so i bought a new crank and new rods and sent them out to the machine shop to make sure everything was in spec and started putting the motor back together ordered pbm hydro and subframe collars picked up version select VI kit and silvia rear valances locally got 50mm rear overs and picked up a 326 wing woke up to this big box from the ups man and it had wheels in it got some more pbm goodies dropped the motor in and got everything mocked up put the car on the ground for the first time in months took the car to my buddies shop and had him weld my fenders and my hydro got the car home and its just been siting on the trailer trying to figure out why the car wouldnt start then the front fenders came in after 3 months of waiting. so i test fitted the rear fenders and the fronts Here's a pic my friend took of my rear suspension a random ass shot finally picked up my ecu. tried plugging it in and it still isnt getting power i think there is something wrong with my fusebox wiring idk i need to find out soon ![]() well just got some brand new ikeya forumula outer tie rods ![]() also my Powered By Max Front Lower Control arm tension rod combo came in ![]() ![]() ![]() tried getting the car off the trailer myself and it got stuck -__- ![]() finally got the car in the garage going to start taking it apart soon to figure out if the reason i have low compression is just headgasket or not ![]() well i snapped a cam shaft -___- ![]() well i installed my pbm flca tension rod combo and pbm inner tie rods. ![]() also ordered pbm drop knuckles and going to order more parts soon. also found a new swap locally i am trying to pick up and should have it after my rip to fd Irwindale. current parts list on the car as of now: Engine s13 sr20det redtop isis intake manifold PBM High mount PBM intake Suspension PBM lca/tension rod combo PBM RLCA PBM Toe rods PBM inner tie rods Ikeya formula outer tie rods PBM Rucas Godspeed traction rods (got them with the car) PBM Rear Drop Knuckles (ordered but havent arrived yet) Wheels/brakes Z32 front and rear brake set up dual rear caliper set up Work Equip 05 18x12-20 OEM 03/04 cobra 17x9+26 Interior PBM hydro JDM Digital Climate Control Prosport digital boost gauge AEM Wideband PBM Weighted shift knob Safc Neo Exterior Dmax +40mm front frenders Origin 50mm rear over fenders Version Select VI kit Dmax roof spoiler |
well i sold my transmission and dual caliper adapter plate so i can buy a new sr swap. well its looking like after i get back from irwindale i will be purchasing my new motor
well i got back from fd it was awesome watched my homies fanboy super hard i fanboyed a little watch my buddy matt field beast it and talked to my other buddy ryan bell about some shit im planning to do with my car
here are some pics from fd ill have more later i met mad mike ![]() and orido ![]() ![]() ![]() ![]() ![]() kado's vk56dett set up super awesome ![]() drift union is coming to wednesday night drifts this week and im picking up my motor next weekend then ill have more updates
@lild415
