![]() Join Date: Jul 2013
Radiator / Fan compatibility?
I've been looking at some new cooling options for my 2jz 240sx, the water pump touches my electric fans slightly, and my radiator has a small leak at a plug on the bottom.
In the course of 3 months, it's leaked to the point where I can no longer see my radiator fluid when I take off the cap. But my question is, does anybody know if Flexalite 410/420 fans are compatible / direct bolt on kinda deal? This radiator: http://www.frsport.com/Koyorad-R1751...4-_p_1747.html With these fans http://www.frsport.com/Flexalite-410...M_p_12555.html Don't mind the dirt and oil, i'll be pulling the engine and cleaning everything once i get back home |
The fans are universal. It just uses a self tap screw to mount them to your radiator. Looks like you'll just have to use the side of the Koyo radiator to mount them.
https://www.flex-a-lite.com/pdf_inst...-133-98111.pdf Something like the link above. Just get measurements for the radiator and you'll know which fan to get. Blah blah. Google will help. |
![]() Join Date: Feb 2012
Trader Rating: (37)
Put your fans on the other side of the radiator. Use Teflon tape on the peacock.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
