JGS Precision 40mm wastegate (fits 38mm also) $180 + shipping
My current turbo setup has a 44mm v-band so this is of no use to me, even as a backup. Never taken out of the box, brand new. $180+ shipping PM me for any questions (These start out at $240 w/o shipping)
From their website: http://jgsturbo.com/wgpg.html All JGS400 wastegates are hard anodized black! A VERY compact unit capable of handling 750+WHP. Excellent for low clearance applications. Our wastegate geometry has been the cure for boost creep in many large engine appilcations. Made in the USA, not another cheaply made imported copy! Engineered, Tested, Machined, and Assembled here at JGS Precision Turbo. Built to survive over 1/2 million full cycles at boost pressures of 40+psi Connections match most 35-38mm wastegates Each wastegate includes a low spring (6-7psi est.), medium spring (8-10psi est.), 1/4" barbed hose fittings, SS exhaust gaskets, and 4 shims. Last edited by flip240; 04-30-2011 at 04:52 PM.. |
