#31 |
![]() Join Date: Sep 2006
maaan, fuuuuck the KA and its notoriety for trapping air. have you heard of a swirl pot? it completely negates burping, it removes the trapped air for you. i got tired of the manual/regular and finally forked over 80 bucks (60 for swirl pot, 20 for lower rad hose connection.) i highly suggest everyone do the same, its well worth it.
a photo of how it works. ![]() and where you can get it. POWERED BY MAX: other companies make them too! idk about the prices or what other companies provide them. |
#33 |
![]() Join Date: Jul 2005
![]() ![]() Feedback Score: 3 reviews
I don't think cardboard in front of the radiator is a good idea.
I consider my problem fixed, I re-bled the system once or twice and now the temperature bounces from 180-185, so I'm happy. I verified there was indeed air in the system by first removing the bleed screw and squeezing the lower tube. I could squeeze it a good bit before any liquid came out of the hole. So I reinstalled the bleeder screw, removed rad cap, inserted fill funnel into the neck and put a bit of fluid in there. Then I removed the bleeder screw until fluid came out and reinstalled it. Ran the engine til warm with the funnel still in place while squeezing the upper and lower hoses, revving the engine, and bouncing on the car, left and right. |
#35 |
I got it back from a professional and now it slightly begeins to overheat. the the tstat seems to open up and i felt the bottom hose get hot once. and now its back cool.
Does the sttat only open when its hot or is it supposed to stay open or slightly open at all times? |
#36 |
what makes you think its slightly overheating? i mean are you going by the stock gauge or what? The thermostat is closed except for the weep hole until it gets really close to the open temp then it should open relatively fast.
#37 |
By slightly; when i was out, it was creeping up and down depending on engine speed and car speed, but still in acceptable levels. It finally went super high and boiled to the overflow. Its a slow speed problem fan or radiator. Back to the shop monday.
#39 |
you said you had a swap
I noticed you said you had a swap, I have heard of the sensors from a 89-94, not working (making it read hot)for a 95-98... making it do the very same thing as you describe. Make sure you have the right sensors for the right year ka... Just throwin it out there
#42 | |
I know this post is old, but, there are issues!
SpaceGuy 85 2003 Nissan Frontier 2.4L |
