Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 01-28-2010, 03:07 PM   #1
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Parts Shop MAX ~Coilovers~ Feburary shipment Preorder-Live quotes & orders in thread!
You can buy stuff and get live shipping quotes right here in this thread!
Simply click the add to cart button to check it out.
As much as I try to get back to all inquiries promptly, I am a very busy guy lately so I have found a neat solution. You just cant beat live real time quotes and processing right here on Zilvia 24/7. I hope you are enjoy the new automation, Thanks! -Dan
We get coilovers only 3 or 4 times a year, and because these parts are so rare and sought after, they are always sold out with pre-orders before the parts arrive so I am posting the announcement for the next round in advance in case you missed them on one of the previous shipments.
When you pay in advance, you get a reservation for parts that are due to land in the USA around the end of february, and we may have them in hand around 3-10.
Heres what you need to know.
~Parts ship out to the USA February 10th
~Models available to preorder in this shipment are:
Nissan S13,S14,R32 - Mazda RX7 FC - Toyota JZA,JZZ
~Shipping usually takes 2 weeks on the water and one week in customs before arriving here
~Price is $1000 cash for locals and around $1060 shipped to west coast $1080 shipped to east coast $1070 inbetween. Feel free to click add to cart for a more accurate quote to your zipcode or if you need a quote to include other parts as seen in our main advertiser's thread you can IM me with the zip and item list
~To reserve a set of coilovers with or without other MAX parts you can pay in part or in full via paypal as long as parts are paid in full before its time to ship to you. If you are not paid in full upon parts arrival, you will loose your place to someone else who pays in full before you so please be responsible about paying them off in time (or simplify everything ny paying 100% up front).
~With the add to cart button, you can order quickly and easily directly from this thread but if you prefer the "old fashioned way" you can also do the following:
~How to order the old way:
(A) Ask me for a parts quote with shipping to your postal code
(B) Send payment to [email protected] on www.paypal.com
(C) Please write the item description in the "message to recipient"
With a lifetime of tuning experience and a passion for drifting competition, Kawamori Eisuke proudly debut'd his signature MAX line of drift and custom parts three years ago. The MAX competition coilovers are thoughtfully designed by Shizuoka’s premier tuner so that you may enjoy superior competitive performance without depending on traditionally overpriced or not so conveniently serviceable parts offered by corporate performance suppliers.
COMPETITION SUSPENSION coilover key features:
  • Full tap independent adjustments
  • Aggressive damping range with fast adjust:
  • Allows you to do 32 clicks of damping change in just 10 clicks!
  • Pillow ball upper mount on front AND REAR!
  • Replaceable shock & customizable spring
  • Super low ride height ability
  • Billet T6061 lightweight aluminum Lower mount with urethane bushing
  • All aluminum components are hard anodized
  • High rigidity/High precision piston rod design exceeds racing standards
  • Adjustable to super low ride height
  • Full thread tap piston and locking collar allows vehicle height to be adjusted independent of the spring preload
  • 2 collar wrenches are included
  • Light weight T6061 aluminum spring perch and locking collar designed to bear the weight of vehicle
  • Spring upper perch provides independance between the spring and the pillowball
  • Racing spring available to special order in custom Kg (even numbers only)
Shock Dyno stats:
Front shock at maximum damping setting: Damping test at 229rpm (.6M/sec) Tension = 748.8KG Compression = 94.8KG
Front shock at minimum damping setting: Damping test at 229rpm (.6M/sec) Tension = 625.7KG Compression = 92.9KG
Rear shock at maximum damping setting: Damping test at 191rpm (.5M/sec) Tension = 642.6KG Compression = 99.5KG
Rear shock at minimum damping setting: Damping test at 191rpm (.5M/sec) Tension = 591.8KG Compression = 94.4KG
MAX S13 Competition Coilovers $1000+sh
click to quote with shipping or to place an order >
MAX S14 Competition Coilovers $1000+sh
MAX JZZ&JZA Competition Coilovers $1000+sh
MAX FC Competition Coilovers $1000+sh
MAX R32 Competition Coilovers $1000+sh
adjuster,pillowball
bottom brackets
spring, locking collars
replacement damper $100ea+sh
MAX Replacement Damper S-chassis Front
MAX Replacement Damper S-chassis Rear
Are your butt cheeks sore from daily driving? We sell 6KG springs to soften things a bit. MAX s chassis coilovers come with 10KG front & 8KG rear springs so if you wnat to run 8KG front, and 6KG rear, just take the 8KG off the rear and put them on the front, and then run the new 6KG pair in the back. 6kg-200mm $60/pair+sh
MAX 6 KG Springs for Competition Coilovers
Article in Drift tengoku this January 2010 features Parts Shop MAX coilovers!
Basically this whole issue is dedicated to people who had their drift car for a while and is looking into changing their tired old suspension.
Question is should you save some money or get the best of the best?
Drift Tengoku has seen alot of companies offereing new suspensions for less and so they decided to do a test.
This was a test of 3 Competitors:
DMAX recommended from Nakamura from Burst $1350
Parts Shop MAX recommended from Yokoi from Mind Control $1000
HKS Hypermax-D NOB spec recommended from Taniguchi $2400
Racing gear was the old worn out coilovers on "Funky's" car who works for dtift tengoku
His car is a S13 with TD06 turbo making 350PS with roll cage, GP sports knuckles 4* front camber 1* rear camber zero toe front and rear.
Testing time was 12 minutes each at mobara twin circuit
tires were new 235 40 17 federal ss595 3kg/m2 pressure rear
This was a blind test meaning the driver did not know which ones he was testing till later.
MAX
located in fujieda city
Yokoi from mind control recommends this because he's been doing good in D1SL with it
Normally they come with 10 - 8 but since Yokoi runs 8/6 thats how they tested it.
side note 6 kg is only in black
A very unique thing about these is that the pillowball uppers for both front and rear both have a spring top had that allows unrestricted pillowball movement.
They liked how most of the construction is aluminum so the whole set weighs 19 kg which is the lightest of all types tested. This is a good mix of Japanese and overseas parts to give you a great suspension for $1000
(they started out on click 4 front and 4 rear out of 8 )
First impression is that it felt stiff and they wonder why because the spring rate is lower than the standard rates. They noticed that the front end of the car feels amazing, and responsive so he could see the difference between this one and his previous suspension. He likes the way it feels when the car gets up on the track curb. The rear felt bouncy so they put the rear on full soft and afterwards it felt better. Funky says with this change the rear feels good and the front has massive traction so when you kick the back out hard, the car has a feeling of control. One important thing to know about how Parts Shop MAX is different from other stiff coilovers is that typically when a car is set up really stiff, its usually it is prone to spinouts, but the opposite was true of p.s.MAX - it had great control.
Racing gear JTC/N1
This suspension was on the car for the last three years but the shock was not blown. The bottom mount bushing was worn. The spring was switched to Eiback 8KG in the front and swift 6KG in the rear. The tester knew right away it was his suspension. He knows this suspension really well, it is easy to kick out the tail but once it starts sliding its hard to stop. Single runs he can drive this suspension bcause he knows it, but the rear is too unpredictable to follow someone well or get consistancy in back to back runs.
They talk about how it comes with many tools for special adjustments. The front has a 2 way adjuster for camber and caster. Rear has a helper spring. Super high quality and beautiful. Has a 1 year warranty. They say it felt great just driving down the paddock, soft. There is no special characteristics to the drift feeling, it was just straight forward feeling, so they tried to see how it feels by clicking the damping one click and that is impossible, it just feels the same, they had to click it 14 times just to tell the difference. There is no extreme characteristics, so it hay be good for a beginner, but for the drivers taste he would prefer something more "edgy".
D-MAX
The tester was really interested in finding out about this suspension because the D1SL was won three times on it. Quality is good, and comes with all the little accessories so thay are impressed with what you get for the price. Started out with 16 out of 32 clicks. He likes this the best for overall balance. This suspension matches the S13 well. Trying the rear softer, there is major understeer so he was like OH Shit and so he tried front and rear full soft and didnt like it either so he put it back to where it was before. Says it is good because the adjustments actually work for dialing in you type of car.
Summary:
Best Cost effectiveness - DMAX
Best Comfort - HKS
Best Purchase ability and steering response - Parts Shop MAX
Unique things about each one:
Dmax has a slotted lower for more camber and a fitting so it wont come loose
Hypermax-D the most positive camber setting could only get it to negative three, so this in in line with more modern camber settigs used with knuckle mods.
Parts Shop MAX - The huge difference in weight of the aluminum brackets - the coarse thread makes it easy to adjust - the issue with the rear balance that they did not have time to fine tune could be dialed in on your car to get the perfect balance with the fantastic front feeling during testing. Being the cheapest is a real plus too!
~~Our thoughts~~
After reading the article, I am thankful that they chose to feature us and that they touched on some things that were important to us like giving you alot of coilover for a little money, but I am a little bummed that they did not touch on some other factors that make our suspension great for alot of people like its low ride height ability so I would have liked to see a compairo of a company with a more similar goals to ours like 326 power (cover cars of this issue) which has spring rates of 14/12 KG. Its necessary to have higher spring rates and proper alignment settings such as a traction rod lengthened for a super low car (and the higher rates dont feel as high as you would imagine when all of the settings are in harmony) Clearly Funky at DT has a preference for softer rates whereas our prefernece is for the 10/8 in cars setup for maximum style and performance. Also the overall conclusion was that DMAX was #1, and thats a little weird since the car testing this stuff has DMAX stickers all over it. Is Funky partial to a certain advertiser in his mag with a multi page ad every month? lol
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 01-28-2010, 03:49 PM   #2
WISH ONE
WISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfectionWISH ONE is close to perfection
Send a message via AIM to WISH ONE
So when will the genesis coupe coilovers be AVAIL??
PARTING/SELLING MY COUPE. PM ME.
WISH ONE is offline   Reply With Quote
Old 01-28-2010, 03:56 PM   #3
DC Dan MAX USA
Trader Rating: (79)
going pretty good, just one more component left to test before production
Definitely the lowest Genesis suspension on earth. Nice ride quality at this height too!
Old 01-28-2010, 04:34 PM   #4
Bumnah
Bumnah's Avatar
Bumnah is an unknown quantity at this point
Send a message via AIM to Bumnah
Enjoy the new automation? - Dan?
Dan the Automator?
bumnah.com/trakpak
Bumnah is offline   Reply With Quote
Old 01-28-2010, 05:13 PM   #5
WISH ONE
I cant wait, let me know when they are available and pricing as well, im going to be looking pretty soon.
Old 01-28-2010, 06:49 PM   #6
JeremyR
JeremyR's Avatar
JeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the rough
Send a message via AIM to JeremyR
edit: i'll pm you, i want more than just coils, haha
drive your car into the garbage and leave it there
JeremyR is offline   Reply With Quote
Old 01-28-2010, 10:12 PM   #7
sincity_sil80
sincity_sil80's Avatar
sincity_sil80 is an unknown quantity at this point
i've been wanting to check these out.. this answers a lot of questions. good thread imo
20 till 3:00 =
sincity_sil80 is offline   Reply With Quote
Old 01-29-2010, 09:31 AM   #8
RPSil13
RPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-knownRPSil13 is making his/her stupidity well-known
are these compatible w/ a JZA70 (89 Supra)
thanks
Art
RPSil13 is offline   Reply With Quote
Old 01-29-2010, 02:07 PM   #9
stinky_180
stinky_180's Avatar
Trader Rating: (26)
stinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to stinky_180
Cool article! You rarely ever see any advertisers showing magazine coverage of their own products, good job! These coilovers sell out pretty fast, so people buy now! I'll be buying your other suspension products in the next couple of months.
SoCal RallyX Coverage and MTB Ride Reports
WheelsDirty
stinky_180 is offline   Reply With Quote
Old 01-29-2010, 05:01 PM   #10
DC Dan MAX USA
Trader Rating: (79)
ok
pms answered
thanks
Art
sorry its JZA80 to be exact.
Unfortunately the USA mags never do a side by side review. It was a real honor to even be secected for review by the best drift magazine in the world. Thanks = )
Old 01-29-2010, 06:16 PM   #11
yingiang
yingiang's Avatar
yingiang is making a name for him/her selfyingiang is making a name for him/her selfyingiang is making a name for him/her self
Dan,
Please give me the exact cost for the S14 coilovers shipped to 75042
yingiang is offline   Reply With Quote
Old 01-31-2010, 11:20 PM   #12
TooFizzle
TooFizzle is an unknown quantity at this point
Ahh hopefully this will still be going on by next Friday. I'll order an S13 set and a set of shorter 10k springs, please!
TooFizzle is offline   Reply With Quote
Old 01-31-2010, 11:27 PM   #13
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
LOL
It's not even happening until February.
Old 02-01-2010, 01:50 PM   #14
DrifTGeeK510
DrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud ofDrifTGeeK510 has much to be proud of
HMMM anyone wanna trade STANCE for there PBM's LOL im being serious lol
DrifTGeeK510 is offline   Reply With Quote
Old 02-01-2010, 08:43 PM   #15
DC Dan MAX USA
Trader Rating: (79)
Originally Posted by yingiang View Post
Dan,
$1072
I dont think you'll make it out of the driveway with shorter springs, please try the setup as-is on your car before you get fancy with mods. Remember you can remove collars if there is some issue with not going low enough but that is pretty rare that someone maxes out max coilovers. lol
Old 02-01-2010, 11:33 PM   #16
TooFizzle
Haha, I know what I'm getting myself into. I've seen how low these go with flipped bracket and removed collars. I just want the option to go even lower should the moment arise.
Na mean?
Old 02-01-2010, 11:50 PM   #17
ILoveMyRHS13
Trader Rating: (25)
$1072
I'm getting close!
Old 02-02-2010, 02:17 AM   #18
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
ALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfection
Send a message via AIM to ALEXTHESUS*PECT
can you make a set of s13 coilovers with the bottom front part of a s14 set?
also any chance on making the y33 top hats for us vip y33 dudes?
how's the van coming along?
TEAM SUS*PECT
ALEXTHESUS*PECT is offline   Reply With Quote
Old 02-02-2010, 07:01 PM   #19
DC Dan MAX USA
Trader Rating: (79)
Na mean?
theres no flipped bracket anymore they are made without the notch now
I know what you mean, theres none in stock so get your order in soon so they can join the shipment, if you want those extra springs its $60 additional
Originally Posted by ILoveMyRHS13 View Post
I'm getting close!
nice work = )
in that case i would probably drill the S13 bottom mount.
or special order it cause they dont make it that way.
I am working on a complete dedicated bolt on solution for Y33 at the moment
we were supposed to do the motor swap saturday but i could not get time in on the lift so who knows but I'll post up progress.
Old 02-02-2010, 10:03 PM   #20
xBlastoisex
xBlastoisex's Avatar
xBlastoisex is an unknown quantity at this point
Any word on the v2's? are they even going to be much different from these.. just dont want to buy these and a month later v2 comeout and be like o damn.. ya know
xBlastoisex is offline   Reply With Quote
Old 02-03-2010, 04:43 PM   #21
DC Dan MAX USA
Trader Rating: (79)
There is no news of a new product release. R&D is pretty slow.
Even if we did release something all of the sudden, and you wanted to upgrade immediately - I'm sure these coilovers would easily sell at a nice price on the used market because they are so rare.
Old 02-05-2010, 08:46 PM   #22
wh0aitznic0
wh0aitznic0's Avatar
I just sent you guys a payment.
<3
Old 02-06-2010, 01:44 PM   #23
DC Dan MAX USA
Trader Rating: (79)
Thank you for your business!
Old 02-08-2010, 10:26 AM   #24
frizzle
In time-out for misbehaving.
Trader Rating: (45)
frizzle is on the path to ruinfrizzle is on the path to ruinfrizzle is on the path to ruin
Feedback Score: 45 reviews
Are S14 coilovers in stock?
frizzle is offline   Reply With Quote
Old 02-08-2010, 03:10 PM   #25
DC Dan MAX USA
Trader Rating: (79)
No, but if you pre-order them you can get some around 3-10. Please read the original thread post for more info.
Old 02-09-2010, 06:32 PM   #26
240sxrb30
240sxrb30 is an unknown quantity at this point
How much are the fender rollers and or they in stock?
240sxrb30 is offline   Reply With Quote
Old 02-10-2010, 02:00 PM   #27
DC Dan MAX USA
Trader Rating: (79)
$220+sh. Thay are in stock now.
#/f/interior-exterio...ng-thread.html
Old 02-10-2010, 10:37 PM   #28
KC240SR
KC240SR's Avatar
KC240SR is an unknown quantity at this point
FC coils shipped to 66205.
KC240SR is offline   Reply With Quote
Old 02-12-2010, 11:06 AM   #29
initial_drifter
initial_drifter's Avatar
initial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of lightinitial_drifter is a glorious beacon of light
JZZ30 Coils Shipped to 98012 please
initial_drifter is offline   Reply With Quote
Old 02-12-2010, 06:43 PM   #30
DC Dan MAX USA
Trader Rating: (79)
$1071 for the FC
$1071 shipped for the Supra/Soarer/SC coilovers which are in stock now.
