Old 02-19-2013, 03:24 PM   #5191
kingston240
kingston240's Avatar
kingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond repute
Just wanted to post up what I was up to this weekend. I know car nuts love seeing some welding porn.
There are lots more pictures on facebook for those interested!
www.facebook.com/HellaFab
kingston240 is offline   Reply With Quote
Old 02-20-2013, 05:19 AM   #5192
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
ITB setup I've been doing for a buddy. I can reproduce these...
oh and his cage is done now too. I just did the welding on this beast. the door bars through the B pillar turned out great. the sit flush with the door skins for super sweet door banger action.
ch1873857 is offline   Reply With Quote
Old 02-20-2013, 05:58 AM   #5193
BoostinIX
BoostinIX's Avatar
BoostinIX is an unknown quantity at this point
Send a message via ICQ to BoostinIX Send a message via AIM to BoostinIX Send a message via MSN to BoostinIX Send a message via Yahoo to BoostinIX
Just got these done from Lee Alexander/Alexander Fabrications
BoostinIX is offline   Reply With Quote
Old 02-20-2013, 04:54 PM   #5194
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
What size rod end?
NEED Bolt kits for your car?
Old 02-21-2013, 06:15 AM   #5195
BoostinIX
BoostinIX's Avatar
No idea offhand, lol sorry.
Old 02-21-2013, 08:58 AM   #5196
DeleriousZ
DeleriousZ's Avatar
DeleriousZ is an unknown quantity at this point
Send a message via MSN to DeleriousZ
Looks like a 5/8" rod end. Head size on them is a little tiny, but if they're quality brand name they should be fine. If it was me I would have gone with a 3/4", but that's probably overkill.
z31 Lovin'
http://imageshack.us/a/img337/2396/lowerit.jpg
DeleriousZ is offline   Reply With Quote
Old 02-21-2013, 09:02 AM   #5197
BoostinIX
BoostinIX's Avatar
I'd measure but already on the car :\ I do know Lee wouldn't use sub-par parts, I'm not concerned.
Old 02-26-2013, 02:14 AM   #5198
godrifttoday
Trader Rating: (82)
But if it was 5/8 I would assume there'd would be play since you have a metric bolt on the subframe
Old 02-26-2013, 09:03 AM   #5199
DeleriousZ
DeleriousZ's Avatar
Most likely the spacers would be machined to accept the correctly sized bolt.
z31 Lovin'
Old 02-27-2013, 09:44 AM   #5200
s13silvia123
s13silvia123's Avatar
I just picked up a Miller Diversion 180, I'm just wondering if anyone can help me figure out why my arc is not straight when I weld. It goes all over the place. The tungsten is sharpen correctly, I used chem sharp to sharpen the tungsten.
Any other thoughts.
Old 02-27-2013, 10:06 AM   #5201
DeleriousZ
DeleriousZ's Avatar
Any other thoughts.
Handbook - Handling the Torch
Most likely a grounding issue, current issue, or contamination issue?
z31 Lovin'
Old 03-01-2013, 11:52 AM   #5202
Csomme
Csomme is an unknown quantity at this point
What color tungsten are you using? I have found that using Chemsharp with purple, orange, and gold leads to a funky arc. Use a grinding wheel and keep it just for tungsten.
Csomme is offline   Reply With Quote
Old 03-01-2013, 12:27 PM   #5203
MADMIKE
MADMIKE's Avatar
MADMIKE is an unknown quantity at this point
Send a message via AIM to MADMIKE
MADMIKE is offline   Reply With Quote
Old 03-03-2013, 10:48 AM   #5204
[email protected]
timmy_sivad@hotmail.com is an unknown quantity at this point
looks awesome!
curious, whats the advantage of this? and are u just using get ITB's modified?
timmy_sivad@hotmail.com is offline   Reply With Quote
Old 03-03-2013, 03:49 PM   #5205
kingston240
Colors didnt come out right being that I took it at night with fluorescents... but...
As always, more pictures on my Facebook page.
Old 03-04-2013, 02:07 AM   #5206
ch1873857
People typically do it solely for throttle response. Why specifically he did it dk. Didnt ask. I personally wouldn't bother with a turbo motor but im sure low end will noticeably benefit. They are slightly modded gtir throttles. The plenum was the only thing that really needed fabricated. Pretty cheap if you know the right people.
Old 03-04-2013, 03:04 AM   #5207
Croustibat
Croustibat is an unknown quantity at this point
looks awesome!
Pros :
it looks cool
it is supposed to give a bit more engine response on NA cars
Cons:
it is bloody expensive and complex (more parts = more chances of failures)
you need to sync the butterflies every now and then - usually at the worst possible time
most of the time the caps on the sync plugs end up leaking - again, usually at the worst possible time
Croustibat is offline   Reply With Quote
Old 03-17-2013, 09:49 PM   #5208
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
First time I've done this much on my own and my welds have improved quite a bit over the past few months. Still using the same flux core mig.
Making my own mustang 2 front end for my 78 courier.
Cross member, steering rack mounts and control arm mounts. All using 1/8" 2x2 square tube and 2" flat stalk.
c72c is offline   Reply With Quote
Old 03-18-2013, 04:31 AM   #5209
ch1873857
Originally Posted by Croustibat View Post
Pros :
it looks cool
Cons:
your an idiot. stop posting.
here is something solid to fill your brains with rather than someones misconstrude opinion.
Benefits of Individual Throttle Bodies - CarsDirect
ITBs are used by automobile manufactures solely on high performance engine due to COST. they dont use them because it looks cool either. the fact that you said that makes me question everything you put on here. thats some ricer shit. i never thought they even looked cool.
ill let you read for yourself. its all there. one downside is that they could become a choke point for force air. However, this is a factory setup. those throttles are designed for that motor. the Rb26 is a turboed ITB motor and they make plenty of power so i think it will be just fine for the 400 bucks he has in the setup.
Old 03-18-2013, 08:20 AM   #5210
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Quick question for you fabrication/metal guys. What thickness metal are you using for extending your lower control arms?
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 03-18-2013, 08:52 AM   #5211
Croustibat
insults insults blah blah blah
Look, i think i have been pretty clear last time; you got a serious mental issue, so go get it fixed. I dont care about you, your life or anything; as strange as it may occur to you, my mind denies your association to the human race whatsoever. You are just an "internet thing" that frankly i could not care less, except your sole presence pollutes every thread you post in by your overall ignorance, harshness and language.
Dont you think there is a reason i ignored your PMs after you posted maybe 10 posts insulting me ? I really hope some mods will pink you for good this time.
TL;DR :
Copy of one of these PMs so ppl can see what you are made off, i did not read them until now, but i guess the other one is the same.
I am going to be as polite as possible. I was very civil in my response to the MAF thread. It seems like a great opportunity for something I could greatly benefit from. You know that though and your attempt to deface me to a potential client/sponsor/partner was quite immature and uncalled for. We have already seen how retarded you can be after attempting to get me banned 4 times for calling you an idiot. You come back to call me a clown? How much more hypocritical can you be? You calling me a clown doesn't bother me. What you said about me doesn't bother me. The fact that you can't let stupid simple shit go and keep going at it like a preteen girl on her first period? Thats annoying. At least if you gonna do this, put up a good fight? Be an adult about it. We dont go cry in a corner around here. Bottom line.. Be an adult or politely fuck off somewhere. If not, you'll find me quite annoying because I will continue to shit talk every thread I see you in. Trust me. You dont get banned for shit talking around here. The mods talk more shit than anyone. This isnt a happy environment filled with lollipops and double rainbows. This place really isnt the place you pal.
Seriously ?
Now as far as ITBs setup go, i have had enough bikes and worked on enough bike engine powered hill climbers to know their downsides, thank you.
Finally, this is zilvia, nor NRR; someone asking for ITBs here is just interested in the bling effect.
Old 03-18-2013, 09:46 AM   #5212
ch1873857
Pink me for good? Was never pinked. And my overall ignorance produce the only tangible answer for the guys question. My feelings aren't hurt for you posting my pm. I had the same thing typed on that thread but i refuse to ruin a good thread which you are attempting to do. If you have something to say pm. All your doing is making yourself look like a fool.
Sent from my SPH-D710 using Tapatalk 2
Old 03-18-2013, 10:52 AM   #5213
DeleriousZ
DeleriousZ's Avatar
If you're going to go through the trouble of insulting someone, at least try and use the right 'you're'.
z31 Lovin'
Old 03-18-2013, 11:02 AM   #5214
ch1873857
Yeah, autocorrect can be a real pain sometimes.
Old 03-19-2013, 07:17 AM   #5215
Sleepy_Steve
Sleepy_Steve is an unknown quantity at this point
Guys, its the internet. It's very important we get back on topic.
Exhaust I made
Hood vent
Switch Panel
What takes up all the time when making a switch panel.
Brake heat shield
Holly fuck, do these not get auto re-sized? My bad.
'95 240 | @SleepySteve72
Sleepy_Steve is offline   Reply With Quote
Old 03-19-2013, 09:48 PM   #5216
IIIXziuR
IIIXziuR's Avatar
That is a pretty cool BMC heat shield you made up.
Just some aluminum sheet bend by hand or with a brake?
Old 03-20-2013, 07:47 AM   #5217
Sleepy_Steve
Yeah, I had some aluminum left over from the hood vent, really thin stuff. Bent by hand with a block of wood on the edge of a table as a 'brake' since I don't have a real one. I had to hammer most of the edges to be sharper and closer to a true 90 since a hand bend can only get you so close.
I keep forgetting lessons I learn from previous sheet metal projects like drilling holes where bends meet to prevent stress risers, and I never really measured that heat shield very closely, so it got seriously un-square when I bolted it on. But good enough for my needs, it should still do its job just as well.
Old 03-20-2013, 05:39 PM   #5218
EvoVIII808
I would like to know this also.. i dont think i have seen this posted anywhere.
Check Out My S13 Build
Old 03-21-2013, 07:06 AM   #5219
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
I normally have another set of bad LCA's that I cut a piece out of to weld into another LCA and then just weld on thicker stuff to add strength. Thats normally because I have a bunch though that we wont use.
When I get home, I will see how thick the metal my friend uses for his arms, he just gets the precut plates at industrial metals and uses those for whatever he needs so.. Ill post here again tonight.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 03-22-2013, 04:08 AM   #5220
ch1873857
for something like that i would you use something beefy like 3/16ths
