Q45 TB wired into S15 SR20DET, need help
anything on how to wire the q45 tb into s15 sr20det harness. there are two plugs on q45 TB PLZ HELP
Cheers Drake [IMG] [IMG] Last edited by richmond82; 05-20-2012 at 07:33 AM.. Reason: added pics |
Bored Throttle Body or Q45 TB - SR20 Community Forum - The Dash
not what i am looking for but helpful info indeed |
These guys sponsor my car and do the coatings
https://www.facebook.com/pages/Rogue...70968462919037 And the color is from Cerakote Cerakote Coatings |
You only use the connector with the wires.
It doesn't click right in? You can double check to see if you need to rewire anything by checking out the Q45 FSM and the 240sx FSM. Index of /FSM |
#8 | |
I am certain its not hard but the issue is that there are two plugs on the q45 tps do i wire in one to the other and then to my SR Harness.
Has anyone completed this ? Perhaps with pics ? Thanks Drake |
You should only need to use the one with the wires attached to it.
You could make a conversion harness by cutting a male Q45 TPS harness and joining it with a female plug that matches with the S15 TPS plug. You can see here, the small black plug isn't used: |
thank you. I will post pics once competed
![]() Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert |
| install, q45, sr20, swap, throttle body |
