#511 |
#512 |
![]() Join Date: Jul 2005
This was a long time ago, just so i could move the car, dont mind all the mess, its cleaned up now
![]() it's REALLY tight back there, i have to install the turbo/mani and WG as one piece, then go under the car and bolt on the turbo outlet, the dump pipe, and then i can put the rest back on. The hose for the crank case breather litteraly touches the dump tube so its wrapped in anti-heat stuff.
613DriftWerks.ca |
#515 | |
it was just temporary so i could move the car.
613DriftWerks.ca |
#516 | |
![]() Join Date: Jan 2003
oops i forgot to mention my freddy intake manifold. is it possible with the manifold and 272's? |
#517 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
SO my numbers are in:
319RWHP 256RWTQ @ 16 PSI 330RWHP 298RWTQ @ 18PSI Had soo many problems on the dyno *5.5 Hours* Greddy RS BOV was opening at high boost... AVC-R was malfuctioning... Couldnt read/turn up boost I was really hoping for more power. We feel that something is really holding this car back - my tuner feels that either the FMIC + Piping are tapped (at their limit) or the exhaust is (highly doubtful) Exhaust: Tomei Expreme Manifold Circuit Sports Downpipe Test Pipe Buddy Club Spec II Catback Cold Side: Greddy VSPL (about 2 yrs old) Apexi Filter and 3" aluminum Pipe ![]() Ill scan My dyno Sheet @ work tomorrow morning
#520 | |
![]() Join Date: Mar 2006
![]() Daily driven |
#521 | |||||
![]() Join Date: Dec 2004
Trader Rating: (58)
Would have a different manifold maybe helped? Who knows...would have different cams helped? Who knows. I have a greddy elbow, and a 3" RSR exhaust....there is just a certain point where that little quarter sized hole just can't vent enough. Garrett also initialyl rated them as a 350 whp turbo. Guys with .86 housings are hitting 450 at big boost. I don't think Garrett ever thought about how well the turbo would actually work on some applications. Quote:
#522 |
![]() Join Date: Mar 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
So whats the wastegate deal to run between 14-20psi solid? I currently have a manual XS that doesn't spike at ALL during any drifting on my t25. I can however go EBC if I need to.
#523 | |
#524 |
I just purchased a new Solenoid and Boost sensor for my AVC-R and a new spring for my BOV.. See if that changes anything - Hey where are you guys reading you boost from? Hotside or Cold Side? What hose? Ive got a Defi Boost guage t'd off the BOV near the turbo - is that correct?
#525 | |
#526 | |
I have a stock SR20 with 2871r, and running and AVC-R.....I am at 285-290 ft-lbs tq by 4000 RPM.....it looks like your power is coming on a little late?
#527 |
Just dyno'd at 17.5 I got 332hp on a dyno dynamics, spiked a little when we played with the settings/gain on the EBC a bit on and got 349hp, then after about 3 hours trying to figure the timing out we relaised the plug gap was throwing it off, few more pulls it stayed at 332-337hp. The shop said the didnt feel comfy going over 18psi in and SR without running race gas.
#528 | |
#531 |
um I think I posted up my dyno, but here it is again...
Stock SR AVC-R set at 17psi R-SPL Intercooler RS BOV 2871R with internal gate tuned by Jeff Evans i need cams and that Intake Mani soo bad
#532 |
I will, waiting on the guy to email them too me, they were still working on another car when I called 30 mins ago, he also mention its a 13% correction on the numbers, and it's a dyno dynamics:
Mods were posted before but here they go: Tomei Standalone MAP Sensor 3.0 bar Version Tomei 260/260 Procam Cams Tomei Rocker Arm Stops Tomei 740cc Inj Tomei Exhaust Mani. Tomei Turbo Outlet Tomei HG HKS Hi-Power Exhaust ORC Kit (ORC409D) Garrett GT2871R .64 56 Trim Greddy VSPL Intercooler Kit HKS SSQV Version 2 Blitz SBC i-D III Boost Controller
#533 |
can someone explain to me why some of you guys run 256/264 cams vs. 264/264s and which combo has the best results? Im pulling my head off to build it and Im trying to make sense of this all before I order anything. Also, at what point would I need solid lifters? the tomei 270s?
![]() Sittin' Sidways Since 2007 |
#534 | |
![]() Join Date: Feb 2006
Man, I wish those guys would post up! Thats the whole reason I made this thread. Do you have anymore info? What boost levels are they hitting at? |
#535 | |
![]() Join Date: Mar 2008
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
^^^^ Great Point !! I would like to see this as well !! S15SPECR was that shop scared that they were going to blow your motor ??? you have enough fuel for it ?? |
#536 | |
I think they didn't want to push it to much, new shop, great guys etc etc...but yeah I think they didn't want to push it. One of the owners said he doesn't tune anything over 18psi on pump. What's up with yours you were gonna put it on the dyno a while back....
#537 | |
Trader Rating: (18)
I haven't had time I been busy with work and weekend drift events. lately my car has been running on the hot side !! (around 190-210) I think my thermostat is going bad !! I'm gonna swap it out and switich to water wetter and distilled water and see how it goes. I also need to put a O2 bung in the downpipe so i can take it to WOLF and get tuned. I promise you that as soon as it get tuned and dynoed I will post up !! ![]() |
#539 |
I'm running FAL thermo set at 75 celc (176), it got up to 90 celc (194 faren.)and stayed there most of the 4hrs on the dyno. For a period of time towards the end one of there fasn pointing towards the car got unplugged. Another thing I noticed was the heat soaking, the cold pipe was almost as hot as the hot side. So we called it a day right then.
#540 | |
Trader Rating: (18)
What T-stat are you running ?? Heat soak is a Bitch !!! |
