![]() Join Date: Jun 2008
gauge cluster lights???
when i turn the lights on everything lights up except the gauge cluster??
headlights, right turn signal( left one does go on either but blinker works), tails.. i took the cluster out to see if the bulbs were bad.. tested umm and they were good. wat now?? |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
i seem to have the same problem with mine i have a dead spot on my hud guage which lights up the battery,brake,basically the dummy lights ..i guess it seems to be isolated anyone with some insight ive checked/searched all i can find was check the fuses ..lol i already did but i still have the same problem at one point i had 2 dead spots on my hud the odomter was blacked out i changed the bulbs and it now works but dummy lights still no good
#3 | |
just the rpm, speedometer, temp n gas gauges dont light up??? wheres the fuse??? |
![]() Join Date: Jun 2006
If you check all the fuses and all of them are fine, check behind the fuse panel right by the brake pedal, if you pull out the panel theres a little white box back there. Replace it and it all your lights should be working again. Happened in a coupe I bought a while back.. the box is called a TC box or something..
Driftphreak87 |
![]() Join Date: Dec 2002
TCU, driver side kick panel. Could also be the dimmer switch.
![]() Join Date: Oct 2006
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
Also look at the back of your cluster, sometimes the head will make the circuit mat bow away from the contacts on the back of the cluster, you can check this by turn the car on with the cluster out in your hands, and just put where all the contacts are on the back and see if the lights come on, I had this problem in my vert and fixed it with a heat gun and low head to get the bow out it, with just a little heat it pulled tight again and all the contacts made connection and all my lights worked.
I had a cool signature |
Invisible rep for you ;0) good job on the pic but yes check everything! Youll find it and let us know what your conclusion is or if your still having trouble.
Driftphreak87 |
WOW thanks 4 pic turns out i dont even have that TCU unit AT ALL
just bought this s13 n has a couple missing things but ill b sure to get that when i go to the junkyard im sure that will fix the problem. thnx 4 all ur help |
