#1 | |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
yes, im writing a paper on gun control for school...I sincerly didnt think i was gonna be this overwhelmed with 3 classes, but i am, full time work and school isnt cake...
im asking for some help here... im 26 and never written a paper in my life, as sad as it sounds...any help is appreciated, sources and essay on the same subject, any thing... here is what i have so far... any help is appreciated. Quote:
PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r
#2 | |
![]() Join Date: Apr 2003
I responded in the gun thread but this may make it easier for you.
![]() Join Date: Nov 2009
I would say 60% of what you are saying is speculation, assumption, and opinion. Any good teacher would tear it apart asking for sources. Its not that those are bad, but it seems like you are presenting them as truth or absolute.
worst>worse is>are You also have a few comma splices. I would take some of the longer sentences and set them up, then in the next sentence explain them further. also, don't write like you talk. I worked in the academics department for a university and this is probably the number one thing professors hate. Read it back to yourself over and over and make sure it is something you would read to a class, not talk with your friends about. also, a paper should be P1 Thesis, then a sum of what you are going to talk about. P2 3 topic sentences and 3 supporting sentences per topic. P3 3 topic sentences and 3 supporting sentences per topic. P4 3 topic sentences and 3 supporting sentences per topic. P5 Conclusion with your thesis REWRITTEN (lol dont just copy paste) and sum up the paper showing how you detailed and explained everything in the first paragraph. if you do an outline first it will help you 10000 times over and you will probably finish quicker. Good luck. I say all of this as a friend. Criticism on the internet isn't exactly the easiest thing to do. School sucks lol but its worth it. I was working 50 hour weeks and took 60 units between two semesters and summer school to finish my degree early. (well not really early as i was 28 when I got it. haha) |
#4 | |
not giving a fuck
i appreciate the help, I know its not even good, its just a rough draft, I still havent gotten my sources together which is what this following week is for (time is against me) i will try and structure this better... i figure i could continue with sources and plug in what coincides with some of what ive written and remove anything that isnt a fact... like i said, 27 and never written one of these, i was just surprise i was able to even write anything 0_o i have to work in MLA format and its 4 to 5 pages, im not one to just do minimum since i do want to learn it... so thank you for your help... any ideas on how to search for info on the subject besides "google it" ? i need to find atleast 4 sources (database, journal, interview, or documentary) and per teachers request have our thesis statement at the end of the paragragh...
honestly, i would use wiki, not as the actual source but to start there and follow their sources. I have a few professor friends who swear by wiki for the beginning for all papers. typically it is true and sourced at the bottom of the page.
reading>you |
high school or college? most high school teachers are idiots and when they even hear wiki they automatically toss it aside. although for good reason as most kids just use wiki and only wiki. lol
#9 | |
![]() Join Date: Jul 2006
Maybe you should read and see that I was reiterating Touge's central point about using Wiki for a source, rather than using it for a starting point for other cited sources. Gj tho bro! ![]() |
#10 | |
Both college and high school. I had to do a paper (college) on a specific disorder or disease, directly correlated from a genetic mutation. MLA format, 4 cited references, can not use the same reference more than 2 times, Wiki and WebMD were not allowed as sources. Little sister is in HS and all of her papers had to follow a specific template (which is getting them ready for college style papers), and she was not allowed to use Wiki and some other source ( I can't remember what it was). |
not giving a fuck
in other words use the sources that wiki used? sounds legit, i also figured id interview a local gun store owner for an interview source... 0_o
#12 | |
AFC #1
![]() Join Date: Oct 2003
Reason most papers are not allowed to use WP as a source is that it's considered a secondary source, not a primary. But, all the primary's are listed at the bottom. As for the interview, That's a whole nother skill. Is it required or recommended for the paper? If not I wouldn't recommend it. This seems to be the standard Reference/Research paper. How well you can find and use reference sources to write your paper. Creating your own sources without bias is an assignment down the road.
#13 | ||
![]() OP i will stress the importance of an outline on any paper. Get some topic sentences down and a good thesis and post it up. Ill check it out when you do. |
![]() Join Date: Dec 2012
![]() Feedback Score: 22 reviews
Hope i helped....
I wrote my paper on gun control (8 pages/mla/6 sources) and this is how i found credible sources through google.Since you're writing about gun control google search this---- ---"gun control" site:.org-----. Instead of ".org" you can replace it with ".edu" or ".gov" This will limit all the fallacy's that you will encounter on gun sites and all the other b.s. sites. I'm assuming you have to have a counter argument. The site's you will find using this method have many counter view points. I also have a few books that i could recommend you to use. Also have you used "ProQuest" or "EBSCOhost??" I dont know if every college has it but it really really helps like a lot. I dont know if this is more of an argument or a solution essay but narrow your topic down as much as possible. |
Lol...... You stated not using wiki but as a starting point for references....
My reply in short.... "If I used wiki in a paper, instructors would not accept it".... Which backs your original statement of not using wiki in a paper. I agreed using wiki as a starting point for references. /facepalm Touge...... Come on man, I expect this from an OV or s12 .... Not from you lol. |
#16 | |
How do you write a paper, and then get your sources together after?
"firearms" not "fire arms"
#17 | |
![]() Join Date: Jun 2007
Dude, if you need to get on Zilvia of all places for help writing a 4-5pg paper on something as easy to find information on as gun control- then you're in for a rude awakening when/if you make it past 100-level courses. Regardless of whether it's for an online or on-campus class- your syllabus and the assignment rubric & course policy should outline what kinds of sources you are allowed to use. Do your own goddamned homework ![]()
Use a fucking library you moron.
Any University/College worth a damn gives you free access to research studies, peer reviewed papers, books, magazines and journals (all in digital format) that you would otherwise have to pay for. My University professors did not accept websites as sources, PERIOD. It had to be a published source.
#19 |
What is this 'library' you speak of???
Next thing you'll prolly say is there is usually at least one in every town; and even more available online. If only it were that easy... ![]()
#21 | ||
not giving a fuck
i was just asking for some help, im not asking anyone to do the work for me, but after many yrs of being part of this forum and helping many others, i apologize for asking anything back... i see no point in going off n a rant since it would be useless...nonetheless if you dont have anything to contribute besides your negativity, stay out of this thread and enjoy your day... i wish i had time, but working 2 jobs and going to school already takes my time, and any free time i do have im doing Hw for classes...so please dont assume im being lazy and that i dont know what a library is, im just press for time and asking for help fuck i did rant... your help is greatly appreciated, ill post up once i have something...thanks agian.
#22 | |
Maybe he hasn't been to the library? There are less fortunate people who did not have a standard education. Not everyone is as privileged as you, up there on your pedestal and all. I am assuming you went to college by the professor comment, but what I don't get is how someone who is educated can be so ignorant. OP ignore the ignorance in here. You are better off posting in the premie section as there tends to be a higher level of respect for other members there. The general population just wants to shit on others and make themselves feel better. Hopefully they will get everything coming to them. |
#23 |
![]() Join Date: Dec 2004
Fuck your shit, Eddie.
Some things to consider for your paper. Interview some folks (casually) at the local gun range, specifically the owner. Some really awesome up-and-coming things are 3d printed guns, which is actually pretty damn viable now. DefenseDistributed came up with the first 3d gun, the Liberator. It's 'easy' to produce, and can fly under the radar in terms of ownership. The project itself was done to 'fight back' against big Government trying to limit our 2nd Amendment Rights. Neat info to spice up your paper. Also, "locally" there was bill (House Bill 972) that passed to allow college students to conceal carry on campus. It's been a welcomed law considering it's Texas but still, it's 'taboo' for the rest of the world looking in. If you'd like me to proof read it and give suggestions on wording and such, shoot me an email man. I'd be more than happy to help in anyway possible. [email protected] |
#24 | |
not giving a fuck
SochBAT ill email you as soon as i write more down...im at work right meow... ![]()
#25 | |
No need to rant, I understand your stress completely- been there; still doing that... I am 42, 4 children & no wife gutting my way thru school- it sucks. Ya know what sucks even more? 3 classes per semester on top of 7-day weeks, 14-hr days halfway around the world outside the wire getting fucking shot at all day for a year. And in that year, I STILL jumped on here & 3 other forums to help anyone I could solve their fucking car problems... and finished close to 30 sem hrs in the process- Welcome to my world. Your shit is supposed to be in MLA format... there are MLA writing guides ALL OVER the web that will show you how to put your paper together... including your outline & drafts. Read your syllabus... ask your professor... Give him/her an advance copy of your rough draft & use his/her feedback to complete the final work. My $.02 still stands- do your own homework... Come back when your rough draft (with references included) is ready for review and I will be happy to provide you with constructive criticism... ---------------------------------------- TougeLove, school is absolutely a grind & quite overwhelming when trying to juggle careers, family etc; but like you said... totally worth it in the end. My parents never prepared me for college. In return for what they never taught me, I bust my ass every day to ensure my kids will go to college right out of high school and not end up in the same boat I am when they are my age. As far as your cute litte 'all this negativity' post- WTF do you expect when a guy gets on here asking for us to provide him with sources & stuff? Dude needs to figure it out for himself; in which case, he will be much better prepared for the next umpteen papers he is going to have to write between now & when he graduates. If he had just said "Hey guys, I just put this draft together... Can anyone with some higher education under their belt maybe review it & give me some pointers?" It would be a different story. If any of my kids asked me to provide them with source material I would do nothing more than show and/or tell them how to get it for themselves... and how to think critically when scanning a source to ensure it supports the purpose of the paper; then keep nudging them in the right direction in the event they get discouraged. No two ways about it- It SUUUUCKS..... However: "Give a man a fish..."
#26 | |
here are some scissors, lets cut him some slack. ![]() ![]() ![]() |
