Old 11-26-2017, 03:27 PM   #1
NathanBerge
NathanBerge is an unknown quantity at this point
coolant line
this is my first sr build and im trying to figure out where the coolant line that comes off the turbo and runs behind the block connects to?
NathanBerge is offline   Reply With Quote
Old 11-26-2017, 03:43 PM   #2
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
coolant line
Underneath the plenum there’s 2 heater hoses. Along these, there’s various nipples that run to the throttle body, IACV, and one that runs behind the block. The one behind the block is what the turbo connects to. If it’s missing or the coolant lines have been modified, any of the nipples on the heater hoses will work. You’ll need to run a hose all the way around the block though
nisileighty is offline   Reply With Quote
Old 11-26-2017, 03:45 PM   #3
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Check here next time you have a small question!
#/f/showthread.php?t=297481
Assuming you have an S13 SR, since you didn't identify.
https://www.google.com/search?q=SR+turbo+coolant+line
http://givemeshred.com/sr20det-coola...implification/
https://frsport.com/Turbo-Line-Insta...ence_t_56.html
https://www.youtube.com/watch?v=Ow8gW_LGMg8
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 11-26-2017, 04:18 PM   #4
NathanBerge
so this is what im working with, im assuming they have been modified (ive included pictures for a second opinion one is of the back of the block and one is looking down into the manifold at the coolant lines) If the case is that i have to used another nipple which one would be best to use? again sorry if this is all basic stuff im new to all this!
Old 11-26-2017, 04:24 PM   #5
nisileighty
Any of the nipples will work, they’re all the same thing. Looks like someone already simplified the coolant lines. Make sure you cap off any extra nipples that aren’t used. The IACV and throttle body don’t need coolant lines unless you live somewhere where it gets below 0.
Here’s how I did mine. I cut the OEM metal tubes that run to the heater and deleted the loop on the back (your car doesn’t have this so you probably don’t know what I’m talking about). One of the nipples on the bottom, I think the original nipple for the throttle body, is what I used for the turbo coolant.
Old 11-26-2017, 04:33 PM   #6
NathanBerge
Any chance you have a up close shot on which one you routed it to
? i dont know which is a vacuum and which is coolant for the throttle body
Old 11-26-2017, 04:35 PM   #7
nisileighty
Don’t run from the throttle body to the turbo.
Run from one of the nipples on the heater hose to the turbo. Cap the coolant lines ON the throttle body off.
Old 11-26-2017, 04:46 PM   #8
NathanBerge
Is this the one you’re talking about ? It’s just to the right of the throttle body and right above the thermostat
File Type: jpeg 7BD0BBF6-C161-4DF9-A94E-A710A6583215.jpeg (130.3 KB, 6 views)
Old 11-26-2017, 04:47 PM   #9
nisileighty
No I capped that one off.
Old 11-26-2017, 04:51 PM   #10
NathanBerge
Okay I see 2 that go to the IACV one on top and one and the bottom does it matter which I use ?
Old 11-26-2017, 04:52 PM   #11
nisileighty
No. Either will work.
Old 11-26-2017, 04:56 PM   #12
NathanBerge
Okay so I’ll use the one on top (see picture) and then just leave the bottom one plugged in or do I need to take the bottom off and cap it
File Type: jpeg FF110505-2C39-4083-A7C8-4E96FECDAC69.jpeg (389.0 KB, 7 views)
Old 11-26-2017, 04:56 PM   #13
nisileighty
Take it off and cap it
Old 11-26-2017, 04:57 PM   #14
NathanBerge
Thank you so much !
