z32 brakes and 350z rotors
OK i got a question for all you... I have z32 brakes all around (30mm in the front) for my 89 240sx.... i was wondering if anybody knows anything about using 350z rotors on z32 brake calipers... I'm mostly wondering about the rear setup... Well to my knowledge I've read up on the front 350z rotors on z32 caliper setup and i believe that a bracket can be used to mount the caliper on to the 350z rotor... correct me if I'm wrong
![]() Join Date: Oct 2007
Yes, for the front you can use a "conversion" bracket to allow for 350z rotors on 300zx calipers.
I'm uncertain for the rear, though.
Blow me, bitches.
![]() Join Date: Mar 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
I only know of a bracket for the front. I don't think the back works.
DD: '05 Saabaru with full JDM STi 6spd swap Project: '91 S13 Hatch SR20 |
just so every one is clear on the fronts, it is the 350z TRACK edition rotors that can be used up front with a bracket.
i don't really see a benefit to running the 350z rear rotors over the 300zx rotors..... |
![]() Join Date: May 2005
Why would you get the rear rotors? 350z rotors in the front and 300zx rotors in the rear keeps the brake bias close to stock
![]() Join Date: Dec 2002
On an Schassis I don't see any need for bigger rotors in the back than the Z32, seems like more hassle to adapt something bigger to work when you already have a bolt on application.
