92 de won't start after mt swap.
Car ran great excluding the auto transmission only having low. Got everything swapped still using auto ecu and lower harness. Reverse lights and dash lights work fine. Engine turns over but won't fire up. Seems to be getting fuel but no spark. Any ideas?
Sent from my KYOCERA-C6745 using Tapatalk |
Guest
Posts: n/a
--Deleted--
I found a forum that said I all the wiring I needed to do was , connect the lower gauge black wire and the low gauge brown wire off the auto shift linkage together. Then take the light green and high gauge black wire and connect to the reverse sensor on transmission and just hook up the vss as normal.
