![]() Join Date: Nov 2011
help with japanese writing on my ECU?
this is the ECU that came with my motor. i can confirm the 550 injectors and z32 maf, but it says tome "something" and T67 (?) "something." the car definitely dopes NOT have a T67 turbo (came with s15 t28) so maybe that T67 is supposed to be 267 (cams?). tome head gasket maybe? any help would be appreciated!
also, I tried pulling off the valve cover to look at the cams, but couldn't find any markings, but i also know that the new Tomei cams are NOT marked... and I'm too mechanically stupid to pull them out to measure the lobes. i'm trying to get an enthalpy tune ecu and want to give him as accurate info as possible |
![]() Join Date: Jul 2006
t67 turbo, wouldnt be surprised if they took it off and throw on a different turbo
(h) is also a trust td06/t67 size also - a trust/greddy td06 on an sr20 is a very common method of making 350whp in japan. which makes sense with your 550/z32 setup.
DODOlogic.ca
![]() Join Date: Apr 2008
Trader Rating: (161)
![]() Feedback Score: 161 reviews
Yeah I can confirm that mark after the T67 means a T67 turbo was used before....stinks about not knowing which Tomei cams were used though.
180SXオタクだ! |
what size?
i had an older set of poncams that werent marked. OP needs to find the tools or someone to help him measure the lobes or he'll never know for sure.
DODOlogic.ca
You can always use this https://dissertationauthors.com/blog...rtation-in-mla service if you need help with writing. I think you could just write to them. But I am glad you solved this problem.
