Old 04-09-2008, 04:28 PM   #1
mxsx25
mxsx25's Avatar
mxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-known
Send a message via AIM to mxsx25
s13 dipstick issue
it seems like every time i really beat on my car, i pop the hood to find the dipstick has popped up a bit..
ive come to the conclusion that it may be caused by blow by since ive been told that sr's are notorious for large amounts of blow by, but i could very well be completely wrong... oh and im running 15lbs on a gt2871r .64a/r if that makes a difference... is this normal?
thanks for any advice guys
mxsx25 is offline   Reply With Quote
Old 04-09-2008, 04:31 PM   #2
murda-c
murda-c's Avatar
Make sure your PCV isn't clogged.
Old 04-09-2008, 05:00 PM   #3
mxsx25
mxsx25's Avatar
stupid question, but where would the pcv valve be located on this motor...? ha i am having a massive brain fart
Old 04-09-2008, 05:37 PM   #4
Snoopy
Snoopy can only hope to improve
Rings... its an sr with a 2871r lol.
Blowby = rings.
Test with a leakdown tester, and or compression check.
As for pcv, not sure where its at on a sr.. but it should be check and serviced (replaced) every now and again but never seems to get done.
88 Rx7 Convertible - Low, Slow, Nice
89 GTUs - Track slut / Missile
Snoopy is offline   Reply With Quote
Old 04-09-2008, 09:47 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If youre looking at the engine from the front, top left corner of the valve cover is a metal nipple, thats the PCV.
You running an oil catch can? Check the hose on the back of the valve cover T. That line is the crank case breather, if its somehow clogged, then your crank case is using your dipstick as a vent.
Or like already stated, really bad blow by.
CLICK HERE!!!
Old 04-21-2008, 12:58 PM   #6
w.tungsten
w.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nicew.tungsten is just really nice
got the same problem.
SR PCV = KA PCV??
w.tungsten is offline   Reply With Quote
Old 04-22-2008, 12:40 AM   #7
fliprayzin240sx
SR PCV = KA PCV??
Pretty sure theyre different. Heck, even S13 SR and S14/15s arent the same.
CLICK HERE!!!
Old 04-22-2008, 09:36 AM   #8
steve shadows
steve shadows's Avatar
steve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfectionsteve shadows is close to perfection
Send a message via AIM to steve shadows
Make sure your Crank ventaliation is going to vaccum before the turbo.
Crank vent is not the same as PCV
Like Me on FaceBook !
steve shadows is offline   Reply With Quote
Old 04-28-2008, 12:34 PM   #9
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection
Send a message via AIM to 1QUICK4 Send a message via MSN to 1QUICK4
Mine did this also every once in awhile, went to napa and bought a new tiny o-ring and it hasn't popped out since.
1QUICK4 is offline   Reply With Quote
