![]() Join Date: Nov 2003
battery Q: cranking amps
Hey guys I just completed my SR swap (still not running right) and I had to use a smaller battery because my recirc valve got in the way. Anyway, my friend gave me his Civic battery and it's slim enough to fit. My question is however, is that the cranking amps is only 620 (I believe) and the stock 240 battery should be 670 correct? Now I'm wondering if this will be a problem in the future. BTW it has been working fine but after our day of cranking the shit out of the engine (wouldn't start in the beginning) the battery light has come on (but very dim). Any input is appreciated, thanks guys
I have a small battery its a pain in the ass... My car has trouble starting, but the battery doesnt need charging... lights go really dim when the car isnt on.
It probably worked good for 1 month, Iv had the battery for about 5 -6 months. Get orignal battery, relocated it to the trunk with a relocation kit.
@woooster on instagram |
![]() Join Date: Feb 2004
just a spot? you got lucky. i guess some idiot spilt battery acid or a batter leaked on to my tray. well i have no battery tray anymore nor do i have the metal under it either .theres now a 5x7 rectangle cut out where i had to get rid of the rust it was so bad i could poke my finger through it. and this is on a s14 you would think that i wouldnt have problems with rust.
Anyhow, getting back to Cold Cranking Amps, (CCA), it refers to the number of amps a battery can support for 30 seconds at 0°F until the battery voltage drops to unusable levels. For example, a 12 volt battery with 600 CCAs means the battery will provide 600 amps for 30 seconds at 0°F before the voltage falls to 7.20 volts (six cells). The higher the CCA, the more powerful the cranking ability. If you live in a cold climate where it snows & get's hella cold, you should consider the CCA rating when choosing a battery. As the temperature drops, the cranking power required by the car increases. However, as more cranking power is used, the amount of battery power available decreases. If you live in warmer climates, like in San Diego or Los Angeles, you don't need as much CCA. Anyhow, hope this answers your question. ID '95 SE |
