Old 07-25-2010, 10:11 AM   #1
Dee
Dee's Avatar
Dee is an unknown quantity at this point
Angry SR20DET: Turbo flange nuts backing off!!!
Ok I'm getting so sick of this crap, I'm having this annoying issue with the 4 nuts that holds the turbo to the manifold loosing up and giving me laggy boost and blown gaskets. I've had this turbo off 4 times in the last month to fix this same issue and I've tried new locking tabs, red loc-tite, and copper locknuts.
I know I can't be the only person that has had this problem, what are some suggestions short of just tack welding the sum-bitches to the flange?
'78 280Z-LSx|76mm turbo|1840cam|8.8 Diff
Dee is offline   Reply With Quote
Old 07-25-2010, 10:23 AM   #2
Sako
Trader Rating: (30)
Sako is an unknown quantity at this point
Feedback Score: 30 reviews
This happened to almost every single SR that I have owned. I did exactly what you suggested; put spot welds on each of the nuts. If you want to pull it off, you can torque them a little and the spot welds break relatively easily.
Sako is offline   Reply With Quote
Old 07-25-2010, 10:23 AM   #3
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
yeah i have these nissan bolt retainer things, oem nissan parts i will sell you for $5each, they solved my problem, i event bought extras but havent needed them, they , the will hold the bolts in place. are you sure you are tightening them down enough. are you using an xo2 gasket, get an oem gasket, that is the other thing that has saved me
handinpants is offline   Reply With Quote
Old 07-25-2010, 10:31 AM   #4
Dee
Dee's Avatar
Yea I've been through two OEM Metal gaskets and I have 2 sets of those locking tabs, they just don't work for shit. I guess I'm just going to have to spot weld them.
Old 07-25-2010, 10:34 AM   #5
Sileighty_85
Sileighty_85's Avatar
Ive never had an issue with the locking tabs, but when i lock them down i try to knock them right on the nut and conform the corners of the tabs around the nut.
Basically I make the whole tab touch the nut. I use a 3/8 drive extension and a hammer
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-25-2010, 10:35 AM   #6
kris
kris's Avatar
kris is an unknown quantity at this point
You can also double up on nuts or get aircraft grade nuts.
The aircraft grade ones basically resist loosening due to vibration and heat better because (iirc) they have a slight change in thread pitch at the end. Downside is last time i checked you had to buy these in bulk and it was like 50 bucks for 100 of them or something.
A small tack weld works but makes it a bitch to remove i would avoid this unless you have no other option
kris is offline   Reply With Quote
Old 07-25-2010, 12:31 PM   #7
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
I've used this Exhaust locking nuts with no issues so far on most of my builds... One thing to consider also is that your downpipe/exhaust is improperly placed.. I've seen some where a good mount of weight holding the exhaust was on the turbo as suppose to the hangers. Flex pipe helps as well.
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 07-25-2010, 12:54 PM   #8
[email protected]
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
i used small tack welds on mine. they havent backed off
R@ddy is offline   Reply With Quote
Old 07-25-2010, 03:14 PM   #9
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
I used to tack weld mine but recently switched to safety wire.
lok is offline   Reply With Quote
Old 07-25-2010, 04:05 PM   #10
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
LIke said above make sure your xaust has all the hangers on it. One trick I have done is to use jam nuts(2 per stud) instead of regular nuts.
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 07-25-2010, 04:06 PM   #11
GroundPerformance
Trader Rating: (44)
^^ Nice... Thats putting ElectroMagnetism to work so it doesn't back out. Mad props to you first time seeing this done.
Old 07-25-2010, 04:16 PM   #12
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
What kind of exhaust manifold do you have ? if you have some cheap ass chinese one.. that might cause it too.
T2 flange surface may not be flat...
Old 07-25-2010, 04:20 PM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Flex pipe and changing a busted engine mount will help ease the engine torquing sideways. Less torquing, less likelier bolts on the elbow and turbo will rattle off...
PS: This is the first time I've ever seen anybody bitch about the locking tabs doesnt work, you sure you used them properly?
CLICK HERE!!!
Old 07-25-2010, 04:37 PM   #14
Dee
Dee's Avatar
This is why Zilvia is the best! I appreciate the responses in this thread, I've got a lot of option to consider hopefully one will work for me.
I'm actually still using the stock manifold and stock T25 with a Circuit sport elbow, but my downpipe is solid with no flex anywhere and the hanger bushings are rock solid so I guess it could be vibrating them loose.
Well it seems like a pretty contraption, you torque the nut down and knock the tab down on the flush side of the nut correct? I've done that and alternatively I've also knocked the tabs so that they wrap around the corner of the nut and that didn't work either they still loosened up and blew gasket.
Old 07-25-2010, 04:44 PM   #15
90hatchie
Banned from the Marketplace
FRSport Turbo Outlet 8mm (1.25pitch) Locking Head Nut
never had a nut back off after these
Old 07-25-2010, 04:45 PM   #16
Sileighty_85
what kinda gasket are you using?
an OEM Metal one or that cheap crap that come with XS-Power (SSAC) paper Crap?
後輪駆動車1番
1986 SR86 - 200ish
Old 07-25-2010, 04:50 PM   #17
Dee
Dee's Avatar
I use nothing but Nissan multi-layered metal gasket, the last two i've blown came out looking like shrapnel out of an I.E.D or something lol.
Old 07-25-2010, 04:57 PM   #18
K_style
K_style's Avatar
Trader Rating: (63)
I do not have Flex either.. I do not think you need it unless your engine sits Horizontal which most FWD cars..
Old 07-25-2010, 04:58 PM   #19
Sileighty_85
Thats crazy, those are some tough gaskets, Ive had mine for over 4 years with out a problem. seem like another issue though, hows the engine run?
後輪駆動車1番
1986 SR86 - 200ish
Old 07-25-2010, 05:00 PM   #20
Carbomb
Carbomb is an unknown quantity at this point
NORDLOCK.
google it.
Carbomb is offline   Reply With Quote
Old 07-25-2010, 05:22 PM   #21
Dee
Dee's Avatar
The engine runs good and health, I don't have any reason to believe there is something wrong with my motor; it's just between my incompetence or just plain ole using the wrong hardware for the job.
Nord lock looks promising but GD effing expensive.
Old 07-25-2010, 05:52 PM   #22
S13NismoStyle
S13NismoStyle will become famous soon enoughS13NismoStyle will become famous soon enoughS13NismoStyle will become famous soon enough
I use these.
McMaster-Carr
They are Oval lock with conical top. The are deforming and dont vibrate loose. Just like the ones pictured above and the ones on FRsport.com
Except these are $5.18 for 50 of them. Good stuff.
Not reusable, but you get so many of them it doesnt matter.
S13NismoStyle is offline   Reply With Quote
Old 07-26-2010, 03:07 AM   #23
fliprayzin240sx
Start off by checking your engine mount. Pop the hood, rev the engine and see how much the engine will twist to one side. If it seems alot, time to change the mounts. If the mounts are shot and your Downpipe/exhaust is too wound up, then itll find the weakest point in your exhaust system to give. In this case, its the turbo/manifold bolt. This is the other reason why I recommend a flex pipe too. Aftermarket exhaust and DP doesnt have the same fitment compared to OEM parts. Something is always off, adding a flex pipe in the downpipe gives you a lil bit of, well, flexibility.
CLICK HERE!!!
Old 07-26-2010, 04:26 AM   #24
niSm095
niSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really nice
niSm095 is offline   Reply With Quote
Old 07-26-2010, 06:36 AM   #25
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
Originally Posted by niSm095 View Post
im surprised no one's mentioned these...factory hardware-
easy and effective.
Reading > You
n240sxfnatic is offline   Reply With Quote
Old 07-26-2010, 10:48 AM   #26
Sileighty_85
easy and effective.
Yeah we did their called "Locking Tabs"
後輪駆動車1番
1986 SR86 - 200ish
Old 07-26-2010, 10:53 AM   #27
stockbee
stockbee's Avatar
stockbee is an unknown quantity at this point
Send a message via AIM to stockbee
I didn't have time to read all of the responses to this thread but I figured I'd throw in my two cents on what has worked for me thus far.
Advanced Auto parts should have some studs and nuts that strip the threads on the studs when you tighten them on. This keeps them from backing off under pressure/load.
They are in the nuts/bolts section. Take a stud with you to make sure you are getting the right sizing for your part. They should be like thirteen bucks and should come with enough for you to do this at least twice if need be. I've only had to do this once!!!!
stockbee is offline   Reply With Quote
Old 07-26-2010, 10:58 AM   #28
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
I was actually a little mad that after I took the time to read the whole thing that that guy didnt and just went straight to posting that picture. Ill get over it.
fullthrottle is offline   Reply With Quote
Old 07-26-2010, 11:27 AM   #29
UNITEDMASTER
To the OP ,if your still having trouble after doing all that you have done , I would suspect your flanges are the problem. Did you do any extended driving on the leaking manifold ??? If so then its suspect ,take it off ,take the studs out ,get a small sanding block or something flat put a peice of 320 grit on it & make a few light passes on the manifold flange. Then look for the high & low spots on the flange,surfacu as needed.
PS- I have seen even so called quality manifolds with jacked up flanges,welding distortion
MR JACKSON.
Old 07-26-2010, 03:30 PM   #30
greenman100
Trader Rating: (18)
greenman100 is an unknown quantity at this point
Feedback Score: 18 reviews
I have these, had to get a ton from McMaster. PM me if you want a set. Once I started using them, no problems.
greenman100 is offline   Reply With Quote
