![]() Join Date: Jun 2012
S14 sr20det 1500 rpm cut
What's up guys, I've dug through decades worth of old posts hoping that someone has encountered this problem before with a resolution.
All my Nissan gurus any input would be greatly appreciated. Things already checked off and changed: Knock sensor Ecu coolant sensor Maf ( tested with a known working one) Ecu same as maf tested with a known good working one O2 sensor swapped with a new one Fueling on the car it has a new pump Oem injectors where cleaned and tested No codes present via Nissan consult. Swapped the trigger disc with a known good one out of my car . https://youtu.be/GsDLvj4Cgow Sent from my Pixel 2 XL using Tapatalk |
