How Do I Install r32 rear diff. on s13???
Hey guys I'm new to 240's haha but I have an r32 rear diff that I want to install on my car. How do I do this? Is it a direct bolt in or am I gonna have to find?fab some stuff up?
2012 Mustang 5.0 ;-) 1993 Nissan 240sx Hatch |
![]() Join Date: Jan 2011
I found it easier to search!
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
I believe the gtr model is similar to a q45 rear swap where you need a 300zx tt driver axle and a q45 driver axle in the passenger side. or use the gtr axles no sure on that part, but u will also need new hubs for the axles and re drill the tail shaft where the drive shaft attaches to the diff.
All this will probably not be worth it depending on what you want to do with your car |
![]() Join Date: Sep 2005
I did the swap with 5bolt axles a while ago, I don't think I swapped rear covers though. R32 GTS? 4.36 vsld into a 1993 SE
yeap i have the r32 vlsd too but i dont know if its the gts one. mine is plug and play, i didnt have to switch the diff cover or anything and i used the 5 bolt axle too. im doing like 70 on the freeway and its around 5000rpm!!! gas mileage sucks too!!!
