![]() Join Date: Jun 2008
Sr20 running really rich and bad
i have a redtop sr20det swapped into a s13
i did the swap not too long ago and its running really bad its running super rich (lots of black smoke and backfiring) it also is hesitating and cutting if i try to get on it and around 3 grand when driving it im pretty sure the MAF is good so im trying to find out what else it could be |
please explain... why would you need an safc?
97 240sx se |
wtf is up with you people? who said he has any mods?
97 240sx se |
the only mods i have are a FMIC and a walbro 225 fuel pump
so it shouldnt really need a tune cus im still running the stock turbo and stock injectors and im pretty sure its not a boost leak |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
How do you 100% know its not your MAF at fault, and/or boost leaks? Because even visually, you can't spot some boost leaks. Make a DIY boost leak tester, their cheap and they'll help you find any.
Also, the MAF's are pretty sensitive so how do you know that it works perfect? |
#10 | |
make sure it's the right MAF, that it's working..and if you have a boost gauge, post your numbers.
97 240sx se |
