I have a few questions about attaching a stock t25 turbo onto a N/A s15 sr20de engine. What all would I have to do to insure I did the process correct and not blow my engine? Other than the turbo, turbo manifold, front mount, and piping, what else would I need to run the engine safely? Also, I heard that I would have to change the compression on my engine to safely run a turbo, which right now my n/a engine is running at 9.5:1 compression. How would I change my compression, if necessary. I am looking for all the help I can get. Thank you very much
![]() Join Date: Mar 2004
Get a good computer and tune the setup on the dyno... The higher compression will help spool the turbo and it will be completely safe once tuned...
http://respectvolkracing.blogspot.com/ |
You should be fine putting a turbo on an NA SR, a 9.5:1 CR is generally considered to be at the upper limit of conservative. |
#6 | |
![]() Join Date: Nov 2010
Its not actually spooling the turbo faster!
#7 | |||
If your'e just refering to CR between 8-9.5 all you need is a solid tune on the best pump gas you can get 91-93. Quote:
Here's a pic for the OP... ![]() |
I stand corrected... Higher compression yields more power in general but does not affect the spool up characteristics...
![]() Join Date: Jul 2005
Everybody around here thats done this has blown their engine. Always a piston failure.
There is not a single one of these S15 NA engines with a turbocharger that has lasted more than 5k miles. Just a heads up. I am not saying its going to blow up also, just that most of the time, these turbocharger installs are not done right. And it needs to be done right. |
![]() Join Date: Jan 2009
Have been down this road before. This is info off the top of my head from years ago, sorry if I'm wrong but I think I'm mostly spot on.
Oil Problems Engine does not have oil squirters, might want to get an oil cooler for your oil. Cam Angle Sensor You want to get the cam angle sensor from a turbo engine. IIRC you can use S14 CAS with the S15 engine. Compression You also might want to try to lower the compression, but I know you can do 8PSI fine, don't go above that you will regret it. Also, might want to look into deeper oil pan + catch can setup for that...get a good tuner too. You're looking at $1500 for a good reliable setup on top of whatever you got. Do it right or don't do it at all. Get NEO AFC and all that stuff and get a good conservative tune.
Man w/ CTSV & a Car Seat
You're in okinawa...you'd be better off/cheaper in the long run/safer to swap in a turbo engine in it than slap a damn T25 turbo on it. Plus with the shitty base gas (86 octane since AAFES suck balls), slapping a turbo on an NA car is a very very bad idea.
If damn kei cars are knocking on that gas, a ghetto rigged turbo setup on an NA car will blow that engine faster a kukojo jumping a black guys dick. |
#14 | |
![]() Join Date: Nov 2004
correct, it will risk the wear on wrist pins and small end rod bearings only.
KA-T ORG-Function over Flush
#15 | |||
It's even simpler to boost this motors considering DET parts will bolt right on. You can even slap a turbo valve cover and just convert to DET ECU and COP. Guys it's simple.. Take care of the tuning regardless which ECU you use and know your limitation stock or built and you will be fine. Quote:
Agreed.. It's to aid on cooling. |
#16 | ||
#17 | ||
![]() Quote:
Also.. If anyone here thinks this motor is not boost worthy and not worth much LMK if your in Socal I'll buy them from you and put that to good use. I'll even buy just the S14/S15 NA Distributor only should you convert to run DET ECU and COP. I actually now have access solid rom tune for this setups running KA ECU.
#19 | ||
I've seen enough folks buy a damn Spec S S15, swap in an S14 SR20 and still save themselves $2-3k from buying a Spec R. Besides, if this kid is asking this kind of question...I highly doubt he knows anything about tuning. Only thing that I can see that folks in Japan would fuck with for this setup is a SAFC. Would you really trust a SAFC on a DE-T on shitty 86 base gas? He can buy off base gas and spent $120 on a tank of gas. |
#20 | |
#21 | ||
I like to use truthful statements when I type to the internet, dont you? Makes it easier for people to sort through the bullshit. Quote:
There are many possibilities to make mistakes for the inexperienced when attempting to turbocharge a non-turbo engine, including but not limited to: oil lines/restriction/return gaskets/bolt pattern OEM limitations are not observed tuning, including fuel system Many folks are simply do have the patience, and cannot forestall all of the risks of modifying an internal combustion engine. Even engineers are learning from their mistakes; everybody starts somewhere, and ends up somewhere, but very few people graduate to rocket science physics from hands on mechanic work experience errors- which means comparing the organic structure of the desired fuel being used with the inlet constituents and properties for the combustion process is not thoroughly being sorted. Many of these jobs are plug and pray. If the op wants a turbocharger on his SR20 engine, I would strongly advise he acquire an engine that comes equipped with a turbocharger from the factory. The cost is not so much greater than what he is faced with now, and the effort will be rewarded with elimination of guess work, except where concerning the quality of the fuel and such variables that cannot directly be accounted for regularly (there is always a risk of bad gas). |
#22 |
Go ahead OP just do a swap. Sounds like your being judge already to be incapable of not being able to do the what's needed to convert properly. But should you consider to think outside the box LMK I'll assist you via PM. good luck on your future build regardless of which route you choose.
#23 |
i had a feeling u could run a s14 ka24de ecu on a s14-s15 sr20de
i hAVE A S13 SR20DE-T running on a stock ka24de ecu with 370cc injectors with a n60 maf...set at 7psi...runs fine... on any na-t setup tuning is the make or break factor...if u dont tune dont be surprised if it blows.... my next build is a s14 sr20de with det pistons and a t3/t4 with a s14 ka24de na sr20de-t is really budget building..but if u get it tuned it will last longer then a ka24de-t for sure
シチサn w/ka20det:in progressシチサnw/sr20det:stolen |
#24 | |
#25 |
![]() Join Date: Jan 2010
bumping this for updates?
| compression, n/a, s15, turbo |
