Old 12-07-2009, 12:28 AM   #1
randps13
randps13's Avatar
randps13 is an unknown quantity at this point
550cc injector Install help
I bought some Sard Denso 550cc injectors part no. 19550-2460. I did some research and they seem to be the primary injectors from an FD S6 RX7 (1992-1995) model. I want to install them on my Redtop SR20DET but the connectors are different. I was told to "de-pin" the stock plugs but I'm not sure on how to properly "de-pin" them or if that's what I even need to do so the 550s could plug in fine. I searched around but couldn't find anything on it. Closest one I found was on here for the secondary 850cc RX7 injector install on an SR. Could anyone please help me on how to "de-pin" the stock plugs/installing the 550cc injectors? Thanks for all your help. Pics of the injectors are below.
It's a work in progress and you'll still get burnt!
randps13 is offline   Reply With Quote
Old 03-18-2010, 02:03 AM   #2
4bangers
4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices
i'm doing the same thing too, does anyone know how I can get this install? thanks
4bangers is offline   Reply With Quote
Old 03-18-2010, 12:04 PM   #3
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
order the connectors. The clips are different from the sr20 and the 550cc (aftermarket denso). I went 550cc to 850cc and both used the same injector clips from denso.
bl3ujay07 is offline   Reply With Quote
