Closed Thread
Old 09-17-2018, 08:07 AM   #1
JoshHH
JoshHH is an unknown quantity at this point
s14 New to the site,freshly rebuilt Ka won't start!!
Just bought a clean 95 240sx with a bad clutch,decided to do a complete engine overhaul. Long story short the rebuild is done but I'm having starting issues. Im gonna explain this the best I can. The car will not start,even with starting fluid,UNLESS, I unhook the fuel feed line from the engine,then I can get it to start with starting fluid. I can also prime the fuel pump and then unhook the fuel line and it will run for about 30 seconds or so till the gas is gone. It will NOT start unless the fuel line is unhooked from the engine,which sounds crazy I know. Flooding?? I'm lost.
JoshHH is offline
Old 09-17-2018, 08:21 AM   #2
silviaks2nr
silviaks2nr's Avatar
Check your fuel pressure and that the injectors are firing properly (not stuck open)- Pull the rail and crank it over for a second and watch them spray. Double check your mechanical timing too. This should really be in the tech section.
'98 240sx 5spd
silviaks2nr is offline
Old 09-17-2018, 08:24 AM   #3
JoshHH
Sorry about wrong section,like I said new to the site. I'll check the things you listed thanks for the reply
JoshHH is offline
Old 09-17-2018, 08:27 AM   #4
zenkicpe
zenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud of
Check that your fuel feed line isn't connected to the fuel return pipe, they could be backwards.
zenkicpe is offline
Old 09-17-2018, 08:58 AM   #5
Bnr32gtr
Bnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enoughBnr32gtr will become famous soon enough
^ this would be my first guess. Don't kno how many times I've seen it happen but it's a lot.
Bnr32gtr is offline
Old 09-17-2018, 09:07 AM   #6
JoshHH
Does the feed go to the back of the rail or the front?
JoshHH is offline
Old 09-17-2018, 09:20 AM   #7
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
+1 for you have your fuel lines swapped
I'm assuming that you have a dual cam KA?
brndck is offline
Old 09-17-2018, 09:25 AM   #8
JoshHH
Yes that is correct
JoshHH is offline
Old 09-17-2018, 10:15 AM   #9
zenkicpe
Who knows who may have bent them previously, just switch them and see if it starts...
zenkicpe is offline
Old 09-17-2018, 10:23 AM   #10
Bnr32gtr
^ exactly
Bnr32gtr is offline
Old 09-17-2018, 10:54 AM   #11
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
we have a thread for this kind of thing already... its stickied to the top of the forum
#/f/showthread.php?t=297481
LOCKED!
dorkidori_s13 is offline
Closed Thread
rebuilt ka24de, starting issue
