![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
GKTech - Steering Shaft Spacers + Tie Rod End Spacers
Solid Aluminium Steering Shaft Spacer
The GKTECH alloy steering shaft spacer will increase your steering response. The feedback that the stock steering rack provides to the driver can sometimes be a bit unpredictable, but with this product response is transferred all the time. A must for the serious driver, both street and track. -Direct replacement of the standard rubber bush Vehicle Compatibility: -Nissan Silvia S13 -Nissan 180SX -Nissan Skyline R32 GTS & GTST -Nissan Skyline R32 GTR -Nissan Z32 300zx Price: 23 AUD (approx. 19.5 USD) Shipping cost: From 22 AUD (approx. 21 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/soli...ft-spacer.html FAQ What's the advantage of a steering shaft spacer? The steering shaft spacer is a direct replacement of the standard rubber bush. As you can imagine, a rubber bush that big, can’t be good. The steering shaft spacer gives you a much more direct feel of the steering. Will this fit my car? Please refer to the confirmed vehicle list in the item description. We do not sell any items that aren’t listed on our website and if we haven’t confirmed fitment on your car, then we don’t know if it will fit or not. Please do not ask. How long does it take to install this steering shaft spacer? The steering shaft spacer will take around 1 hour to install with the engine in the car. If for some reason you don’t have the engine in the car, it will only take 5 minutes or so to install the spacer. Is this steering shaft spacer something I could install myself? Yes, it’s certainly not a difficult job to install the spacer, it’s just time consuming and you need some patience (and small hands) Stainless Steel Tie Rod End Lock Spacers These spacers slip on to the end of either standard or aftermarket tie rods and allow the tie rods to travel further into the steering rack which creates more steering lock. Generally providing around 15 degrees more steering angle. Great for drift or getting out of parking spots. - Easy DIY installation - CNC machined stainless steel Vehicle Compatibility: - Nissan 180SX - Nissan S13 Silvia - Nissan S14 200SX - Nissan S15 200SX - Nissan Skyline R32 GTS-T (2WD) - Nissan Skyline R32 GTR (AWD) - Nissan Skyline R33 GTS-T (2WD) - Nissan Skyline R33 GTR (AWD) - Nissan Skyline R34 GTT (2WD) - Nissan Skyline R34 GTR (AWD) - Nissan Cefiro A31 Price: 12 AUD (approx. 10 USD) Shipping cost: From 22 AUD (approx. 21 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/stai...k-spacers.html FAQ What’s the advantage of tie rod end spacers? Tie rod end spacers give you more steering angle by allowing your tie rods to move further into your steering rack. Will this fit my car? Please refer to the confirmed vehicle list in the item description. We do not sell any items that aren’t listed on our website and if we haven’t confirmed fitment on your car, then we don’t know if it will fit or not. Please do not ask. How wide are these spacers? The tie rod end spacers are 6mm’s wide each. Are these spacers safe to use? We have sold tie rod end spacers for many years without any issues. That said, as with all of our products they are strictly sold for off road use only and are not intended for use on public roads. Is this price for a pair or just for 1 spacer? The price listed is for a pair of spacers, 1 spacer for the left of your steering rack, the other for the right. Where do these spacers go exactly? If you pull out your tie rod, slip on the spacer on the end that goes into the steering rack and then put the tie rod back into the steering rack. How much extra lock should I expect to see from these spacers? You should see around 15 degrees of extra steering lock which is quite significant. For any inquiries please e-mail us at [email protected]. |
