![]() Join Date: Dec 2008
custom braided brake lines?
im looking to get some lines made and i dont know who or where to look.
i need something to go from my brake booster to about half way across the engine bay, i need to re-route the current stock set up for clearance issues with my top mount set up, any suggestions?
grip like roots, float like leaves. wtb s13 sus. |
Just make your own. All you need is a bender and a flare tool.
Summit SUM-900675 - Summit Racing® Tubing Benders - Overview - SummitRacing.com http://www.summitracing.com/parts/SUM-900311/
#3 | |
anyone know what the thread pattern is for the brake booster? i need to run a 90 right out of it. and a tight 90 so it would need to be a fitting... is it universal?
![]() Join Date: Apr 2004
I have full braided brake lines from cylinder to caliper.
If you're local just cut off the fittings from the hardline and take it in to get the correct thread pitch. Or you can bring them the master cylinder. |
#6 | |
wow cant believe i didnt think of that.. thanks . /thread.
