Old 08-25-2020, 12:43 AM   #1
UglyBoi180
UglyBoi180 is an unknown quantity at this point
180sx Headlight Problem
Hello, Im having an issue with my right headlight where my low beam will not work.
My high beam works and both the high and low beam works on the left side. It is not a bulb as i have replaced it with multiple different bulbs and no luck. It's also not a fuse as all have been tested and work.
Has anyone else had this problem?
Thanks
UglyBoi180 is offline   Reply With Quote
Old 08-25-2020, 02:14 AM   #2
My!
My! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enoughMy! will become famous soon enough
check under your fender and see if your harness has been rubbed by your front tires.
My! is offline   Reply With Quote
Old 08-25-2020, 04:13 AM   #3
S14rebuild
yes check the harness running under the driver fender. Seen the head light connector corroded , and the wires come off the connector
Old 10-19-2020, 01:36 AM   #4
UglyBoi180
Just want to reply with my solution, My indicator stalk was the issue and after replacing fixed all my issues!
180sx
