89 s13 redtop swap cluster wiring
hey everyone, I'm finishing up a SR redtop swap on my 89 s13 hatch and I'm having an issue with my cluster.
so just to clarify i swapped to a dohc cluster and switched the dash connecter. the issue is that nothing reads on the dash except the fuel but it has a mind of its own. i followed the Frsport guide and wired up the 5 or so wires that it tells me and it still reads nothing. i have done countless hours of research in trying to find an answer on the forums before i posted this. thank you, i appreciate everyones input and please no flaming lol. |
It starts up and I can rev it just fine
I have yet to drive it down the street. I just have to figure the cluster issue out and bleed the clutch then I can drive it. the ecu is a 62 series |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
Look behind the cluster
See if any cooper lines have a burn Verify the wires on the dash plug is right There is a black wire that goes to the dash plug.....run that to another black wire |
