#91 |
Got mine in the mail today.
Quality looks top notch. I'll probably end up buying another core to redo the Vmount in my fc. I love you guys in a non gay way! Quick question, what did you guys use to cut out the material that needs to go?? Plasma cutter?? |
#92 |
Thanks for the feedback!
a cut off wheel
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
#95 |
How wide is the S14 kit from inlet to outlet pipe (inner edge to inner edge, not center to center)? (ie what is the largest width radiator that inlet / outlet would clear?
#96 | |
69.8 cm
#97 |
Hmmmm, because the stock S14 AC condenser core is slightly under 69.8 cm. If more sheet metal was cut, your core moved down and forward, a little bend to the passenger side AC hardline, and some creative upper AC condenser mounts then you might be able to retain AC.
#100 | ||
it was pretty hard to develop the worlds first HMIC kit without revamping the AC system and messing with the hood latch and left and right core support beams. That makes it a lot harder to install, and people who love their AC more than the motor can buy some random front mount. Part of the goal of this project was to get obstructions out of the way of the radiator because before when I'm drifting I have the heater on blast just to help the car stay on this side of extreme water temps in willow springs now my car loves me, seriously like 20*c cooler Quote:
$250 shipped. I wonder why though, we built them for our custom IC and our custom IC is built for them
#102 |
got it , will dispatch these ASAP
#103 | |
#104 |
does the texas BBQ and crazy girls make up for it?
#105 |
whitersx02's s13 silvia face customer fitment photos
#107 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
I was just worried the TB would be in a different place than the sr one. I've ran an sr smic for two years and had to modify the coldpipe to get it to fit. I'd feel alot more comfortable seeing this on a ka first, before buying this, then having to modify it to fit right. I don't have any experience with the ebay sr13 sr20 fmic and fitmint of that setup. I'll prolly purchase this kit anyways if the deal is still on it a month or so, I need to rebuild the front end first...
#108 |
and are your guys hood spacers still for sale?
tipsyturtle instagram:@s14rob @tipsyturtle |
#110 |
You buy the pipes that go with the motor (and turbo), the intercooler is the same. HOWEVER the nylon spacer & top bolt length in the hardware pack is different so just tell me the car's configuration when ordering.
If your KA-T manifold places the turbo in the same spot as SR then there is no problem with compatibility, just like how KA-T guys can use SR elbows and downpipes.
#113 |
looks like it will go out sometime this week.
the manual adjustment is right on the motor so i would say thats not possible.
#114 |
How much would just the intercooler be with out the pipes?
#115 |
$200 + Shipping,fees
#117 |
inlet pipes are on the way, I'll announce when they're ready
#119 |
Thanks, says it should be here on the 27th. I cant wait!
#120 |
