hi i need help my sr20det is making a funny noise, can anyone give me advice? Here is a video.
Sr20det Rod knock , bearing, or lifter? - YouTube |
![]() Join Date: May 2008
Trader Rating: (26)
That sounds like you slipped a bearing. When I had my ka, it made the same noise when you would give it gas and I found out I slipped a connecting rod bearing.
![]() Join Date: Sep 2005
That sounds like it's in the head, also vacuum and exhaust leak!
East Coast? Where, and why is the check engine light on?
i believe it does have a leak, prob exhaust, its not a check engine light its a hiccas light, from low steering fluid. I took that valve cover off and was going to pull cams and look at the lifters. But i realized i was not sure where the timing chain tensioner release was. I read that you have to take off the oil pan some where to get to it. I am not really sure. So i was thinking of pulling the engine to make it easier to check all areas for problems. I drained the oil their were no metal shaving , i check with a magnet. I flushed the coolant, pulled and tagged the wiring , removed intake and inter cooler piping to begin engine removal. Then it got really hot out. I live in the Tri state area.
Game plan for lifter check
![]() hows this sound zip tie timing chain to camshaft sprockets to keep timing remove bolts holding camshaft sprockets to cams remove fuel tubes remove camshaft brackets remove camshafts remove rocker arms,shims,rocker arm guides to get to lifters ???? Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting |
You don't have too remove the sprockets from the cams, zip tie and remove tensioner, then move cams out of the way. leave shim and guides in there place , remove the rocker arms 1 at a time, bleedeth the lifterseth. then the rest is all reversivfy. lol
