Ka24det rebuild question
Im currently in doing a rebuild on my dual cam for ka-t stock spec everything pistons rods rings bearings. Should I adjust ring gap? Im re using pistons just replacing all the bearings and rings. Im planing on 8 to 10 psi
550cc Rc enthalpy tuned ecu Walbro 255 pump Te04 turbo 60trim Z32 maf blow through setup Front mount ic Sent from my SM-G950U using Tapatalk Last edited by RomulanS13; 01-22-2018 at 05:45 PM.. |
#3 | |
Sent from my SM-G950U using Tapatalk |
![]() Join Date: Sep 2014
My suggestion would be to at least see if the gap with all of the new rings installed is the same from piston to piston. Then cross reference your measurements with what is stated in the FSM.
Gap at the very end of stock spec
MRP Manufacturing |
![]() Join Date: Apr 2013
in my experience, stock pistons will fail at the ring lands. I got two weeks off my reused oem pistons, went supertech after that and ive been going strong for 3 years stock rods, t28 pushing 12psi. still I have been told many times that stock pistons can handle your setup and I dont doubt that. Why not go forged? its worth it.
![]() Join Date: Jun 2004
Trader Rating: (73)
If you're going KA-T upgrade your pistons and ring landings AT LEAST. I blew out my ringlandings on my first or second drift event after install.
Save yourself the downtime. Do some searches. People are always selling KA pistons.
I really didnt want to but ill be going over sized with the look of fhe cylinder wall on cylinder 3. Forged it is but i just dont justify almost a grand on parts and a re-tune.20180122_152738.jpg
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
The amount of money and quality of your work will affect the longevity of your build. I guessing you want your build to last. Spent the money. Get the right parts and tools.
#13 | |
![]() Join Date: Jan 2009
Trader Rating: (25)
#14 | |
GM2 (SW/AW)
You're giving up? Pathetic. Take out a loan and sleeve that block. And stop coming up with excuses to cheap out and go another route. DO IT
www.superstreetonline.com/how-to/engine/0805-turp-ka24de-build-up/
![]() Join Date: Oct 2013
I had a stock bore KA with wiseco pistons dropped in it last 3 years before the cylinders need to be bored out.
The $1,000 needed to make your ka last at 3-400whp is 1/2 of what you'll spend on an SR swap that stock vs stock is rated for the same HP internals wise. |
#16 | ||
GM2 (SW/AW)
surely didn't spend $1000 nor was I able to successfully destroy the engine. just saying
