#991 |
![]() Join Date: Oct 2004
Has been already talked about a few pages back... ok maybe 10 lol... anyways, its useless to run a GT30xx bottom mount because of the manifold designs and the restriction of running a GT30xx on T2 housings. So all in all don't bother....
Turn and Burn!
#993 | |
anyways, the hks wg comes today! to ill install it tonight and play tomorrow!!! anyone have any new dyno sheets?
want to be in the 500whp club by the end of next year!!! |
#994 |
But seriously who has moeny to test the setup? T2 Frame is going to cost you like 400... manifold etc etc... its going to be hard to find a side by side comparison of a T2 vs a T3 GT3071R or something.... At this point....
Turn and Burn!
#995 |
**edited**
Tomei S15 runs a 3071/76 bottom mount T2 setup IIRC, and they have some very impressive numbers. Not sure on the other specs though Last edited by s15specR; 08-28-2009 at 02:45 PM.. |
#996 | |
I am confident the GT2876R is the best option for those of you who MUST hit the true 400 WHP mark with bottom mount turbo, and it is possible on pump gas too... The base 2871R just does not have enough compressor to run out into efficiency that high like the 3076 wheel
Like Me on FaceBook !
#997 |
![]() Join Date: Feb 2006
I just got a tune and the turbo doesn't feel AS crappy. Still off and on but not as bad. Only running 10 psi though.
Im thinking of keeping the turbo and changing my engine to a RB25 and getting a T3 exhaust housing... |
#998 | |
#999 | |
So you still on the 2871R? T3 exhaust housing would be awesome top mount... SRs are kewl but RB's are definitely better, I just have a hard time looking for parts if I do swap over that is all... SR's are fun...
Turn and Burn!
#1000 | |
![]() Join Date: Jan 2007
but i have a full built race car with carbon shaft,straight cut dogbox, stroked out SR,solid lifters and cams with 12.5mm lift and i cant even make that power on 1.2bar with my setup running a k3-450R turbo which is MUCH MUCH bigger then your 2871 your dyno reads wayyyyyy too high mate......... why dont you take it to another tuner with a proper dyno?? Id be skeptical seeing a figure anything past 350rwhp on a fully built SR20 and 2871.... even using high boost! and pump gas just makes it sound even more suss!
#1001 | |
![]() Join Date: Jun 2008
![]() ![]() ![]() Feedback Score: 11 reviews
#1002 | |
My bottom end is 100% stock and for the head i just have the basic titanium valve springs/retainers, HKS Step 1 256/264 10.5mm cams, and GReddy RAS. so granted the DynoJet reads higher (which im not denying although it feels good) i KNOW that i can pass 350whp on a DD Dyno. funny thing was, when we did a base run at 12psi on the dynojet it read 317whp. so it actually read lower. i doubt that altitude levels would make THAT much of a difference. seeing as how people state that the dynojet reads an average of 13% higher than a DynoDynamics. which would mean that the DJ should have read around 368whp at that psi level. so if altitude can make a 51whp difference then i should be WAAAAY higher than the 381whp that i put out at 16psi. so, contrary to what people say about the dyno difference in my case it was the opposit and the DD read higher. I'm sure that Steve shadows wouldnt pull some shady shit and try to make the DD read higher than what it really is putting out just to claim a tune. he has too much rep already to pull some lame shit like that. I hear people (mostly from down under) rag on the dynojet and other dynos that we use in the US. however, from what i have seen from my recent experience and from other people, the dyno's dont make THAT MUCH of an insane difference in numbers. my brother inlaw put down 203whp with a stock rb20 with raised boost to 14psi dropping to around 10psi on the top end on a dynodynamics dyno with a stock ECU. what would people say to that? maybe the DJ does read higher, but in my case it read lower. and each run was consistant and consistancy with a dyno and a good tuner is what we should be looking for IMO. you should run your set up on the DD at 12psi and see what you put down? let me know of what the numbers are so we can play your game of comparison. with a fully built stroked motor and a bigger turbo you should be putting out much more than my 100% stock bottom and basic head with a "small" 2871r .64 simple set up. cant wait to see your numbers!! btw, in the next couple weeks ill do a 20~22psi tune with water/meth and post up the results. maybe oneday people will just be able to say "good job"
want to be in the 500whp club by the end of next year!!! Last edited by deukalionS14; 08-29-2009 at 07:41 PM.. |
#1005 |
I am convinced there is something up with the camshafts or maybe the VTC, because every consecutive run we did on your car the power seemed to dip more and more.
Also I would check the turbo out and most possibly your VTC. Something is getting worse and worse. VTC going out can cause this kind of slow power drop off. You should definitely be reading lower on the Dyno Dynamics. this means you would probably be reading at like 300 now on my DD. Never had a 2871R car do that before. Also Try running some colder plugs and then advancing your timing in your map up 2 degrees. The Air Intake temps that day were really HOT - which might have contributed to your power dropping. The DD is just straight off road power so It cant be that. There is defintiely something that is getting worse are worse, like a vacuum leak or maybe your turbo starting to get more drag on it. Me and Mike were kind of baffled at why the car wouldnt make more and more power as we increased your boost more and more. Shoot me a PM, that's pretty crappy if your power keeps falling off more and more. PS. did you ever get the boost controller to work properly?
#1006 | |
he-he-he He is not the norm at all. Just check with the aussies on here. 380 is usually the limit. I am convinced that Camshafts and Intake manifold greatly limit the potential power you can make with the 2871R. In the case of the larger T3/T4 50 Trim turbos its actually the opposite case but that 2871R is really a small turbo it needs a "larger front door" sort of speak to get more out of the compressor it has. Big intake cam and intake manifold cars see the highest and best results
#1008 | |
The turbo is fine as i have checked and had my entire set up looked over by Otis at RB performance before heading over the tuner in Hesperia which was BEYOND hot and still pulled 381 consistantly over 4 or more pulls. As for power increasing as the boost increased. there was a difference just from a "butt feeling" between 12psi and 15psi. the one thing that we did was change the fuel pump to a circuit sports unit and get it tuned. other than the wg opening at 16psi and not holding 18 everything was great. the power "drop" can easily be blamed on the drastic alititude difference between mission viejo and hesperia. anyone who lives in Riverside and above and has driven to carlsbad or san diego can tell that the car drives much better down there due to alititude and climate change. these two tunes have been done in two VERY different enviroments. one being in Mission Viejo during the month of May (which is no where was hot as now) and the other done in Hesperia during the month of August in 90+ degree weather. the new tune is spot on and had no hiccups other than the boost not holding. yeah, the boost controller is fine and since i changed the wastegate it holds 18psi with no problem. i just need a new turbo inlet gasket ![]()
#1009 | |
also, the more research i do on the 4 dynos (mustang dyno, dynojet, dynodynamics, and dynapack) that most people use the more interesting information on "readings" i find. Modified mag also did a expirament with these 4 dynos and the mustang dyno actually read the lowest followed by the dynojet, then dynodynamics, then the dynapack came in reading the highest of the 4. also, you can't put a percentage difference for each dyno as it seems the percentage difference changes with the power output. people have said between 6~16% difference between the DJ and DD dynos but a difference of 10% is HUGE. so, the best bet is to just use the dyno for what its made for. tuning and power upgrades output comparison. i need to stop with long posts lol damn im bored
#1011 | |
![]() Join Date: Mar 2009
I remember reading this i was surprised of the outcome Dyno Dash - AWD - Modified Magazine |
#1012 | ||
#1013 |
![]() Join Date: Aug 2007
^^ Have you eliminated low compression in any of your cylinders as a possible culprit for your set-up not being able to achieve the numbers you're looking for at this time? I.E. have you done a compression/leak down to determine the health of the motor?
#1014 | |
The reason why i didnt make the power i wanted this time was because of my wastegate not holding the boost. i want to boost 20~22psi with water/meth in the near future.
#1015 |
Sorry man.
It's definately USA dynos read high. I have a shitloads of mates here who even run TD06-L2-20G complete TRUST kits ( brand new, 8cm ) today a mate of mine tuned his.... 17psi boost with a cleaned up head and springs with Jun 264. 11.5mm camshafts this car was stock bottom but had the fresh reco head and cams with springs guess what power it made? 348.66rwhp now that in the states would be wayyy too low right? its actually quite high here hahaha... Theres no way on earth a GT-RS (2871 52t) can make that power unless its running massive cams and 20+psi boost. ive seen it too many times on differnt dynos in australia and differnt tuners too so no excuses.... But its good to see you can make that power in USA.. maybe go and drag race it to see what MPH and times you pull down the quarter mile? heres a link to my mates fresh TD06-L2-20G chart. this was on a higher reading dynapack dyno ( hub dyno from NZ).... ![]() and a video of my car on 1.1bar boost with a run in tune ( 365rwhp or so.. Mainline dyno) YouTube - Testing S13 Silvia JUN 2.2L KKK turbo 1.1k boost its definately the dynos in usa. im satisfied by that because you guys make 300rwhp from stock T28's and 350rwhp on 2871 52ts....... quite easly too with mild mods . and low boost. which is the total oppisite to australia... and other countrys.
#1016 |
Its because you guys are below the equator, the oxygination and the centrifugal gravitational rotation mass make your turbo's spin backwards.
I'm going to the quarter this week with a friend to see what traps I put down. My 60fts will suck because my tires are gay though. Car feels like mid 300's right now according to my pantelones. |
#1017 | |
![]() Join Date: Sep 2008
I still got them tires AND I'm off today! |
#1019 |
hahaha good call :P but yeh.. comeone 350rwhp from a 400hp rated turbo
come on man... maybe if it boosted to the shithouse then id believe it.lol
#1020 |
Werd.
I know a few peeps who run 2871's on their stock crank SR's w/ stock cams that get ~380whp+. They're pushing 22+ psi at it to achieve this. It's altogether therefore possible. These turbo's looove boost. Cams just make the same numbers possible at lower boost. |
