![]() Join Date: Mar 2008
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
All aftermarket parts are in great to almost new condition, mostly under 500 miles. OEM parts are old as most SR's/240's. I don't sell junk, all parts are clean and in good working order but in used condition. Everything is sold AS-IS in good working condition. Feel free to ask any questions via PM or AIM. Buyer pays shipping and is optional on all parts.
THIS IS A "FOR SALE" THREAD NOT "FOR TRADES" #1 complete thermostat assy. with new OEM Nissan thermostat less than 500 miles - $60 SOLD #2 S13 SR20DET coolant upper water neck w/screws - $50 #3 S13 SR20DET turbo compressor outlet neck w/ screws - $30 SOLD #4 OEM T25 oil drain return tube $15 #5 OEM S13 SR20DET dipstick tube and stick $40 #6 OEM Nissan slave cylinder bought new less than 500 miles w/SS braided line fits SR/KA/RB - $40 SOLD ![]() #7 Greddy T25 turbo outlet elbow w/ divider plate - $140 SOLD #8 OEM Nissan S14 power steering reservoir assy. - $60 #9 Stance ST9 oil block adaptor for SR20DET w/ new oil pressure sensor replaced less than 500 miles - $120 ![]() #10 AEM 3.5bar MAP sensor w/ pigtail and mounting clip - $100 #11 SARD fuel pressure regulator (FPR) with FRSport NOSHOK 0-160psi gauge kit and new fuel lines, clamps and mounting bracket - $200 SOLD #12 OEM Z32 MAF connector harness pigtail - $10 #13 complete lower harness (alt, battery, starter, ground, fuse box) off S14 chassis - $50 SOLD #14 AEM boost control solenoid - $50 SOLD #15 OEM Nissan oil filler cap - $5 ![]() #16 OEM Nissan stock intake tube with intact spring coil - $10 SOLD #17 OEM Nissan throttle body coupler hose - $5 SOLD ![]() #18 stock sr20det valve springs 16pcs - $10 #19 stock sr20det cam gear set with nut and washer - $50 SOLD #20 stock sr20det valve springs 16pcs - $10 #21 stock sr20det cam gears only - $20 SOLD ![]() #22 ATI dual 52mm gauge pod for S14 240SX - $20 SOLD #23 complete AEM 52mm serial data stream gauge for EMS - $140 #24 AEM 52mm wideband uego controller gauge - $150 SOLD #25 Greddy/Trust 3" SR20DET steel downpipe w/ gaskets, nuts, bolts O2 sensor bung - $140 SOLD ![]() HAD TO ADD SOME MORE SINCE THREAD IS DOING SO WELL. NEW ITEMS ADDED 11/02/11 2PM #26 S13 SR blacktop IACV used, stripped plastic screw. was replaced with new one because of idle issues but can be cleaned and used - $40 #27 ACT 600225 XACT StreetLite Lightweight Flywheel 14.1lb 89-98 SR20DET barely used for less than 500 miles - $180 SOLD SOLD SOLD #28 OEM Nissan SR20DET exhaust gasket unused from a OEM gasket kit / single layer - $10 SOLD #29 Nismo slave cylinder for S13/S14 used in perfect condition - $100 SOLD #30 OEM Nissan oil squirters (under pistons) 4pcs with screws - $80 #31 OEM Nissan coil packs in good working order 3pc (sold 1) - $50 #32 Stock S13 SR20DET throttle body with S14 throttle pulley, will include stock throttle pulley and working tps sensor - $80 #33 OEM Nissan knock sensor off a S13 SR20DET (harness sold) - $30 SOLD ![]() #34 Custom made throttle cable bracket for S13 SR Greddy/ISIS intake manifold w/ N15 throttle body - $40 #35 Stock OEM Nissan lifters 12pcs - $20 SOLD #36 S13 SR timing chain guide with screws - $10 #37 OEM S14 drivers side switch housing for SE models - $5 SOLD #38 OEM S14 passenger side switch housing - $5 SOLD #39 OEM S14 passenger side switch housing - $5 SOLD (all switch housings have broken mounting points that are commonly broken) ![]() #39b (oops) OEM Nissan AAC IACV was bought new about 3 years ago for $400. Perfect working condition, not as dirty and clogged as most of the older iacv's that come with motorsets from japan and has the metal screw that wont strip like the older plastic ones - $180 SOLD #40 S13 SR20DET stock MAFS (Mass Air Flow Sensor) works - $45 (not sold but currently missing from my last move) #41 OEM Nissan gasket for T25 turbo compressor inlet - $10 #42 OEM Nissan SR20DET alternator rebuilt to 90amps and only used for about a year. Comes with all brackets and bolts - $150 #43 OEM S13 SR20DET turbo manifold with heat shield. Comes with used T2 gaskets, nuts, bolts, washers, locking tabs (will include #28 if not sold before this purchase) - $50 SOLD ![]() #44 OEM Nissan Valve Cut 17065-05U00 for fuel pump system. If you dont know what it is, you probably dont need it. Brand new unused - $10 #45 KA24DE starter USED condition - $45 #46 Stance oversized water pump pulley - Used in mint condition with belt in almost new condition - $60 SOLD #47 OEM Nissan 11810-86G01 valve control / PCV valve BRAND NEW - $12 SOLD #48 Used stock OEM shifter - $10 #49 Used OEM Nissan S13 SR20DET starter of a blacktop motor - $120 ![]() ***NEWLY ADDED 11/09/2011 *** #50 Brand New Signal Auto Aluminum Cooling panel for S13 (fits silvia and 180 fronts) - $50 picked up or $65 shipped #51 OEM shifter boot and ring bracket - $50 shipped #52 OEM shifter boot and ring bracket painted black - $50 shipped #53 OEM upper rubber shifter hole boot - $50 shipped ![]() ![]() ADDED 11/14/2011 #54 S13 SR20DET Blacktop head, OEM valves, cleaned and decked with new supertech valve seals. Nothing stripped or broken but missing cam caps. Put a machine shop to work or just use it as a mock up - $60 SOLD SOLD SOLD ![]() #55 OEM S13 SR20DET crank with 1 bearing damage - $60 #56 OEM S13 SR20DET flywheel - $20 #57 OEM S13 SR20DET transmission bellhousing alignment plate - $50 SOLD ![]()
http://squarespokes.com/ Last edited by besTint; 08-17-2013 at 06:28 PM.. |
organized for sale thread FTW
BUMP |
Trader Rating: (81)
lowball PM's are being ignored.
all other PM's replied. Sold items are being updated hourly. added more item> BUMP
http://squarespokes.com/ |
![]() Join Date: Sep 2009
Hook me up with the knock sensor and turbo compressor elbow shipped to Orlando florida? pm me pls
Thanks!
1997 KOUKI SR'D SKEPTRON POWER!
#16 | |
Trader Rating: (81)
Thanks for the bump! enjoy. Quote:
HOOKUP sent via PM
#20 |
Trader Rating: (81)
Thank you, hope you get to enjoy everything =)
Thank you for the bump. PM'd you price shipped to Hawaii. Sorry but shipping is too much, dont think it'll be worth it. weekend bump!
#23 |
item #43 shipped to 29630
#24 | |
Trader Rating: (81)
PM SENT are you sure? shipping is $29.61 @ 18lbs i would love to sell it but i think you'd be better off finding it local and avoid shipping on something like this.
http://squarespokes.com/ Last edited by besTint; 11-15-2011 at 03:36 PM.. |
#25 |
Would u separate the shield ?
#26 |
Trader Rating: (81)
sorry, it'll make it harder to sell. but if someone wants to pick up just the manifold i'll let you know.
http://squarespokes.com/ Last edited by besTint; 11-19-2011 at 12:22 PM.. |
