![]() Join Date: Feb 2008
Trader Rating: (32)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 32 reviews
S13 sr20det
I have a s13 sr20det black top.. 99.9% stock! comes with everything you need to swap! accoring to the cluster the motor had 54k!!
-Pre-wired harness -Ecu -Maf with intake tube -turbo and manifold -tranny -EVERYTHING! -ps pump! Looking to get $1800! For 2300 obo I'll include a Aluminum radiator,greddy turbo elbow,s15 7 layer gasket,new radiator hoses from nissan,extra t25 and a godspeed manifold and a Front mount core perfect shape! let me know! Looking to sell cause need money!! orr! for $1000obo you can buy the long block! will come with cas,Intake manifold,alternator,. give me $1000 solid and I'll include the turbo side with a god speed manifold clutch and flywheel and a maf! and maybe a power steering pump! with bracket no turbo side,tranny,harness,ecu,ignitor chip,or any other parts! just the long block, no ps pump! The engine has a apex head gasket!
![]() *-- SPIDER --* Last edited by spiderlone; 09-06-2009 at 12:29 PM.. |
Yo i purchased this engine off of you and its BUNK! The bottom end is shot! Oil all up in the spark plugs!
I should have known it was bad since you even drove 2 hrs to deliver it to me... |
#10 | |
Trader Rating: (32)
oil in spark plugs coudld be valved cover seals.. why dont you chdck that? idiot.. And the motor ran in my car so ur doing something wrong..
![]() *-- SPIDER --* |
Trader Rating: (32)
did you even start it? Did u hear a rod knock? Haved u stareted It? Or are you going off on spark plugs? im sure you didnt start it at all yet..
![]() Join Date: Dec 2008
honestly ... really? before you accsue someone of selling bad stuff make sure you have done proper trouvle shooting.. it could be alot of stuff.. if its jstu cranking over.. lose of spark... READ UP ON THREADS tons of people run into this problom. could be in injector YOU NEVER KNOW. this guy has broguht something t o me before and it wasnt bad..
#17 | |
He ALSO told me it was a blacktop SR, it's not. Its my fault for not looking at the front of it as well as the ECU as i was in such an awesome mood to be finally picking up my SR. I've PM'd him multiple times and he WILL NOT respond to any of them. O'well, you live and you learn. |
#18 | |
Trader Rating: (32)
#22 |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
Reviews section is there for a reason.
Use it. ![]() |
