Old 07-04-2015, 02:18 PM   #31
Nonsense
Nonsense's Avatar
Nonsense is an unknown quantity at this point
Originally Posted by ALEXTHESUS*PECT View Post
so it turns out like most nissans that the q45 and s13/s14 parts are mostly interchangeable. so with nobody stocking q45 coils in the states, and then costing 2500+ per set, once i learned of this alternantive it was a no brainer. yokotas13 aka grant really fueled the info for this a couple years ago and i just started the process.
Forgive me for the bump,
But Im am about ready to do this conversion myself on my 99 Q45t.
The thing is,
I read a different thread on the vip forums and most of them mentioned that you need to use y33 top hats for the coilovers in the front.. but rear bolt up.
Is this correct?
Others say you don need and they bolt right up..
Im planning on going with S14 suspension all around.
Heres my set up:
S14 Front Spindles
Feal 240sx Coilovers
Battle Version Ruca, Traction, Toe, and Front Tension Rods
Nismo Front lower control arms
Tein Inner/Outer Tie rods
I just want to get the most information possible and see if there is anything else I would need.
Just want to make sure if i need the Y33 top hats.
If so, where do I get them?
Thanks,
Nonsense is offline   Reply With Quote
