![]() Join Date: Jun 2005
ac/heater blower fan not working
I did a search, and went back 22 pages.
Like title says, ac/heater blower fan not working at any speed. When I had a maxima, my blower fan sudden only worked on the fastest speed. Replace the resistor and it fixed the problem. Is it the same fix here? thanks for any help.
71, 72, 74 Celicas; 85 AE88 hatch; 89 S13 hatch; 04 IS300 5MT |
![]() Join Date: Dec 2002
Nope. A bad resistor would give you full speed fan only, but not lower speeds. I'd say it's the blower motor itself, unplug and check for both power and ground. Remember the ground is variable through the resistor so check it at each speed setting. If so the motor drops out with three screws.
