I beg you! Wire harness help- FULL LIST OF SPECIFIC Q's
I'm going through this mess of a harness. It is an s13sr harness(i think) that is wired for an s14 chassis. I went through the entire thing, wire by wire. Below are my results. Would you please be so kind as to tell me which ones are CORRECT or INCORRECT. Even if you check one of them off my list, i'd greatly appriciate it.
Pin 106- Green wire w/ solid yellow wire- CUT Pin 3- Yellow w/solid red line- CUT Pin 16- Solid white- CUT w/ connector on end(not plugged to anything) Pin 19- White w/ silver dots- Connected to thicker white wire. Ground wire (from pin 48) is in same loom as the thicker white wire Pin 20- Solid white- Still connected as normal, but has plug spliced into it Pin 22- White w/ silver dots- Connected to wire from Pin 30, then into larger solid white wire Pin 31- Black w/ silver dots- Connected to wire from Pin 40, then into solid black wire Pin 38- Connected- 2 red wires spliced into it(about 2 feet long. not connected Pin 39- Connected- 2 green wires spliced into it(2 feet, not connected) Pin 116- Spliced into 107,108. All three go into 1 black wire w/ silver dots Pin 26- Blue w/ solid yellow line - CUT Pin 43- Blue w/ solid white line- CUT Pin 45- Blue w/ solid white line- CUT Pin 48- Spliced into with SIX other wires. Please help as much as possible. I'll mark them off or deleate them as soon as each harness modification gets addressed as ok, or not-ok. |
