Sr20 timing chain and camshaft issue
I ended up breaking a rocker arm today. I've never removed a camshaft before and I got too confused/ anxious and removed the bolts that hold the camshaft down. I realized now that I shouldve put the cams in tdc (?) where the colored links are at the 11-1 position, but I tried to do this after I had removed the camshaft bolts. I ended up popping out the camshaft and sprocket out before they were in the right position. What should I do as a next step and how to I make sure that my timing wont be off?
![]() Join Date: Sep 2005
Remove the chain tensioner, then set it to be installed then put it to the side. Use the new slack to create enough room to put the cam gears back on. if you can along with the tensioner, then set the engine to TDC.
If you can't? continue removing the cams then with both cams removed set the engine to TDC. (I usually move the chain manually when doing this, but you don't have to. It's a superstition of mine) After the cams are out put the gears on, then the rest is FSM procedure. Your tensioner should already be out. Tip I usually zip tie or pipe cleaner the chain to the cam gear, whenever I do anything that involves the chain. And when doing the head, I paint the link and gear, just for that quick reassembly aspect.
#3 | |
........yes it helps you install the chain easier, when you reinstall it, it will ratchet out when you make your test rotation
Ok sorry for my lack of knowledge on this subject, thanks man
That's what this forum is for, lol!
my short answer was yes so i added the ........, then I edited it for the explanation. if you're doing this now, just post back if you have any other ?'s or problems
Yeah Im working on this right now but im going to finish up soon, im going to be working on it everyday until i get it fixed so i will def be posting back on here
#8 | |
#9 | |
nevermind I managed to move it
Don't worry about lining the links up just yet, get the number 1 piston TDC and get the cams installed correctly, with the chain on. Then count the links, 11 links from dot to dot. put the tension in, make a few rotations, you can even try to see if the dots line up, but the main goal is no binding, or abruptly stopping of the crank
#16 | |
#18 | |
Looking at the front of the engine and the first piston is number 1
number 1 need to be at TDC, that's aka TDC. Place a 27mm(IIRC) socket on the crank and a screwdriver in the spark plug hole, rotate the crank clockwise until the zero degree mark on the crank comes up, and the screwdriver stops moving up. That's TDC. Quote:
#20 |
Do you know the torquing procedure for the cams? You need to follow them. They're in the FSM. The tensioner is still out right? Leave it out until the cams and chain is installed. Also keep an eye on the rocker arms, guide and shims, make sure they stay in place and verify they are still in place when done.
#21 |
The cams are up in the air because those valves are the ones that are going to be open, so please follow the fsm tightening procedure or you could strip the threads
#22 |
Oh I know the torquing procedure, I just figured torquing down cams that dont sit perfectly was a bad idea. And when I say cams are in the air I mean the whole rod, not just the lobe
#26 |
Is that a trick question? Post some pics of what you're talking about.
Sent from my Overclocked Debloated SIII
#28 |
alright hang on
