![]() Join Date: Jul 2007
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
S13 SR20DET Parts Galore with Pics OEM and Aftermarket New and Used
Some Parts I've gathered over the years. Just trying to make some room! If you dont see it, feel free to ask as I have alot of little stuff not listed like various speciality bolts, gaskets, ect...
S13 SR20DET Left Overs New and Used, oem and aftermarket : -S13 US chassis to S13 SR Harness with Z32 MAFS Plug - $150 Shipped -Turbo Blanket, this is a large one I had on my T3/67, was chrome coated but most of chrome has flaked off, not the prettiest but it def still gets the job done! Paid $100 new - $30 Shipped -FULL RACE/Garret Core 500+hp Front Mount Intercooler HIGH HP APPLICATIONS 950+holding -$500 shipped firm -S13 SR 5sp Transmission, Great Condition never had an issue with it! -$150 I WILL SHIP!!! OEM PARTS S13 SR20DET: -OEM Valve Stem Seals - $20 -OEM flywheel bolts - $20 -OEM rear main seal and housing - $20 -Engine Mount Brackets - $40 pair -SR S13 Lower Water Neck/ Thermo Housing(oem silver, blacks sold) = $20 -CAS/with Polished Cover - $100 ($80 w/oem cover) -Brackets(Intake, Engine Mounts, ect) - $-- -Main Crank Girdle - $30 -Baffle Plate(the one oil pickup runs through) - $10 -Oil Squirters for Pistons(bottom of block)x6 - $10 ea -Bearing main caps/set of 4 - $20 -Oil Block - $20 -Knock Sensor w/subharness - $30 -Main Bolts - $20 -Crank Bolt, gea, pin key, - $20 Misc Bolts, Banjo Bolts, Rubber Hoses, Lots of randomness off SR's, anything you need, just ask! HERE IS A LINK(s) TO MOST OF THESE PARTS: SR20DET Full Build Part Out pictures by brsilvia - Photobucket stuff for sale pictures by brsilvia - Photobucket
#18 | |||
#/f/sale-items/21037...uidelines.html |
