![]() Join Date: Nov 2011
You need the NA diff which is the R200 for shorter gears ( Same gear ratio as the 240sx)
You'll have to change your hubs out for the Z32 NA hubs because you'll have to use the 5bolt axles. Unless your Q45 is one of those few tat had the 5bolt axles and not the 6bolt ones (Star shape). |
