Spirit Of Ecstasy
![]() Join Date: Dec 2007
Sr running rich enthalpy tune
My afr idling in the 11's WOT 10 flat. I only see 14's under light load at cruising speeds. boost gauge showing 20 at idle witch seems good. looking to get my idle back to what it used to be along with my afr at WOT, not sure what changed to cause this to happen. Car used to idle at 14.8-15.3 fullboost used to be 11.6
Mods S15 turbo HKS 740 Freddy intake Circuit sport fuel rail Fmic Z32 maf Recirculated bov Full exhaust Any ideas ? |
Spirit Of Ecstasy
So I found a possible issue the vacuum line from the fpr to the intake mani is super super soft it's prob collapsing when I played with it I saw my idle go from a 11.3 to a 14.9 I have my bets on this being it the corporate! Well see i will be replacing after work
#4 | |
Worth making sure this is correct also.
Like Me on FaceBook !
#6 | |
Replace the line and check your ignition timing, adjust as necessary.
My SR20VET |
No worries, she fucks me all the time...
My SR20VET |
Spirit Of Ecstasy
Think the maf sharing a ground with the e fan could do it? I just bought this car a few months ago I have been slowly but surly going through it trying to get everything de janked
I'd put them on separate grounds to be safe, even if it is not the issue. MAF ground by itself, fan ground can go with the chassis ground.
![]() Join Date: Jun 2007
^^He's lying. Everyone knows that everything under the hood should be tied into the MAFS ground.
But seriously, hope the vac line fixes her.
I have not personally seen one bad enthalpy tune. make shure every thing else is 100% b4 blaming the tune for instance you can havd a vacuum leak and not know it or where it is and think the tune is off. so you install a safc and make the afrs better but you never fixed the problem just made it look better
![]() Join Date: Aug 2009
Well I got bad enthalpy tune. On the map he send me its pretty generic. He put enrichment in my cruise are that should be close loop. TP value above 45 is all 30. 5 to 15 TP is close loop till 4500 rpm. I am running rich everywhere except idle and below 30 mph.
